0015322 | ParaView | (No Category) | public | 2015-02-13 16:17 | 2015-09-06 12:17 | ||||
Product Version | 4.3 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015322: Annotate Global Data does not work corectly | ||||||||
Description | From a user: AnnotateGlobalData does not work properly with GlobalData. Rather than printing only the value of the GlobalData for the particular time step being displayed, it prints the entire array. Ex: I have GlobalData ModeNumber=(1,2,3,4,5,6,7,8). Then, AnnotateGlobalData shows: "Value is: (1,2,3,4,5,6,7,8)". | ||||||||
Project | Sandia | ||||||||
Attached Files | FileProperties.png [^] (73,953 bytes) 2015-06-22 11:15
FilterProperties.png [^] (85,956 bytes) 2015-06-22 11:16 | ||||||||
(0034217) Alan Scott (manager) 2015-02-13 16:26 |
I incorrectly missed a part when cutting and pasting this bug. You may need to load a dataset with modeshapes, and click the "has modeshapes" button (properties tab, advanced.) |
(0034590) Utkarsh Ayachit (administrator) 2015-06-22 09:11 |
Cannot reproduce. Here's what I did. + Open can.ex2; check "Has Mode Shapes" on Properties Panel; Hit Apply. + Create "Annotate Global Data" filter. Change "Select Arrays" to "mode_shape". Hit Apply. + I see "Value is: 1". + If I change the "Mode Shape" slider on the Exodus reader and hit Apply, the annotation changes as expected. |
(0034597) Greg Vernon (reporter) 2015-06-22 11:14 |
Alan & Utkarsh, I'm having this issue on exodus files. I've added some screenshots demonstrating this behavior on Windows 64-bit v4.3.1 First screenshots shows some of the file properties, namely the states of "Has Mode Shapes", "Animate Vibrations," etc. Second screenshot shows the filter properties. Both screenshots show the global data filter printing the entire data array, rather than just the current value. |
(0034599) Utkarsh Ayachit (administrator) 2015-06-22 12:06 |
Thanks, Greg. I think I know what's going on. Do you have a sample dataset to share? It's not a big deal if you don't have one. |
(0034600) Greg Vernon (reporter) 2015-06-22 12:12 |
No problem, unfortunately I don't have any I can share. |
(0034605) Utkarsh Ayachit (administrator) 2015-06-23 15:03 |
Merge requests: VTK: https://gitlab.kitware.com/vtk/vtk/merge_requests/335#note_19251 [^] ParaView: https://gitlab.kitware.com/paraview/paraview/merge_requests/179 [^] |
(0034608) Utkarsh Ayachit (administrator) 2015-06-25 09:09 |
Fix merged in master. |
(0034613) Alan Scott (manager) 2015-06-25 21:14 |
Tested master, linux, local server. (My numpy is bad remote server.) |
2015-02-13 16:17 | Alan Scott | New Issue | |
2015-02-13 16:26 | Alan Scott | Note Added: 0034217 | |
2015-06-07 00:41 | Utkarsh Ayachit | Target Version | => 4.4 |
2015-06-07 14:11 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-06-07 14:11 | Utkarsh Ayachit | Status | backlog => todo |
2015-06-07 14:12 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
2015-06-22 09:04 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-06-22 09:04 | Utkarsh Ayachit | Status | todo => active development |
2015-06-22 09:11 | Utkarsh Ayachit | Note Added: 0034590 | |
2015-06-22 09:11 | Utkarsh Ayachit | Status | active development => customer review |
2015-06-22 09:11 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-06-22 09:11 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2015-06-22 11:14 | Greg Vernon | Note Added: 0034597 | |
2015-06-22 11:15 | Greg Vernon | File Added: FileProperties.png | |
2015-06-22 11:16 | Greg Vernon | File Added: FilterProperties.png | |
2015-06-22 12:06 | Utkarsh Ayachit | Note Added: 0034599 | |
2015-06-22 12:06 | Utkarsh Ayachit | Status | customer review => todo |
2015-06-22 12:12 | Greg Vernon | Note Added: 0034600 | |
2015-06-23 15:03 | Utkarsh Ayachit | Note Added: 0034605 | |
2015-06-23 15:03 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2015-06-25 09:09 | Utkarsh Ayachit | Note Added: 0034608 | |
2015-06-25 09:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-25 09:09 | Utkarsh Ayachit | Resolution | unable to reproduce => fixed |
2015-06-25 21:14 | Alan Scott | Note Added: 0034613 | |
2015-06-25 21:14 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
