0015268 | ParaView | Bug | public | 2015-01-19 04:37 | 2015-09-06 12:18 | ||||
Reporter | Gautier BUREAU | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Platform | Mac Pro | OS | OS X Yosemite | OS Version | 10.10.1 | ||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015268: Visualisation problem in 4.3 of an .scl file but works in 4.1 | ||||||||
Description | The visualisation of the results of a thermal fem simulation is not displayed correctly in paraview 4.3 and the versions below until 4.1 in which the correct result is displayed. An odd value of 10e22 appears on a node during the visualisation even if it is not present in the result file. The problem disappears with the use of the 4.1 version. The correct result was displayed with the client Ensight also. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
Attached Files | bug_report_paraview.zip [^] (41,459 bytes) 2015-01-19 04:37 | ||||||||
(0034115) Joachim Pouderoux (developer) 2015-01-27 10:05 edited on: 2015-01-27 10:05 |
Gonna check that. By the way this is a VTK bug. |
(0034116) Joachim Pouderoux (developer) 2015-01-27 10:38 |
The bug has been fixed in VTK. http://review.source.kitware.com/#/c/18973/ [^] Change Iecbec49f: Fix EnSight Reader BUG 0015268 Classical problem of string copy-move without considering the trailing null char. Change-Id: Iecbec49f62ab983486caaaafc74cae5bbda2953f |
(0034117) Joachim Pouderoux (developer) 2015-01-27 10:59 |
Topic merged in VTK master tree. |
(0034139) Utkarsh Ayachit (administrator) 2015-02-03 08:20 |
SUMMARY --------------------------------------------- Topics merged into master (v4.3.1-119-g6d9aca5): (VTK) 15284_refactor_paraview_interactors 15298_fix_exporters_in_python (VTK) icet-opengl2-fix minor-fixes new-baselines-20150202 push_specA_cinema (VTK) pvweb-support-http-rpc-servers safer-unified-bindings-arg vtkmpi-inclusion-fun fix_pgi_issues |
(0034239) Alan Scott (manager) 2015-02-18 16:34 |
Tested using attached example file. Thanks for providing it. Tested Linux, master, local server. |
2015-01-19 04:37 | Gautier BUREAU | New Issue | |
2015-01-19 04:37 | Gautier BUREAU | File Added: bug_report_paraview.zip | |
2015-01-19 04:38 | Gautier BUREAU | Project | ParaViewVR => TBD |
2015-01-19 04:38 | Gautier BUREAU | Type | incorrect functionality => feature |
2015-01-27 10:05 | Joachim Pouderoux | Note Added: 0034115 | |
2015-01-27 10:05 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2015-01-27 10:05 | Joachim Pouderoux | Status | backlog => active development |
2015-01-27 10:05 | Joachim Pouderoux | Note Edited: 0034115 | |
2015-01-27 10:38 | Joachim Pouderoux | Note Added: 0034116 | |
2015-01-27 10:59 | Joachim Pouderoux | Note Added: 0034117 | |
2015-01-27 10:59 | Joachim Pouderoux | Status | active development => gatekeeper review |
2015-01-27 10:59 | Joachim Pouderoux | Resolution | open => fixed |
2015-02-03 08:20 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-02-03 08:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-02-03 08:20 | Utkarsh Ayachit | Note Added: 0034139 | |
2015-02-18 16:34 | Alan Scott | Note Added: 0034239 | |
2015-02-18 16:34 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
