0015256 | ParaView | (No Category) | public | 2015-01-12 05:15 | 2015-09-06 12:18 | ||||
Reporter | Joachim Pouderoux | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Platform | OS | Windows | OS Version | x64 | |||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015256: ParaView x64 installation path | ||||||||
Description | Under Windows, in 64bits and by default, ParaView is installed in "Program Files (x86)" instead of "Program Files". See http://en.wikipedia.org/wiki/Program_Files [^] | ||||||||
Project | TBD | ||||||||
Topic Name | 15526_Fix_DefaultWin64InstallPath (on superbuild git) | ||||||||
Type | usability | ||||||||
(0034074) Joachim Pouderoux (developer) 2015-01-13 04:12 |
This bad default behaviour seems to be related to CMake for which a patch has been submitted (but not merged I guess): http://public.kitware.com/Bug/view.php?id=14211 [^] According to Dave (https://www.mail-archive.com/cmake@cmake.org/msg40151.html [^]) this should do the trick: IF (CMAKE_CL_64) SET(CPACK_NSIS_INSTALL_ROOT "$PROGRAMFILES64") ENDIF () |
(0034075) Joachim Pouderoux (developer) 2015-01-13 04:56 |
Change Iacc81cef: Setup default NSIS install root for Windowx64 Default install path is (for instance) "c:/Program Files (x86)" which is supposed to be reserved to 32bits apps. Instead it should be "c:/Program Files". Fix that behaviour. Change-Id: Iacc81cefac6f7ab0c9b55050ba88ca3a682b8f20 http://review.source.kitware.com/#/c/18844/ [^] |
(0034485) Alan Scott (manager) 2015-06-04 17:46 |
Deleloper tag in git. Closing untested. |
2015-01-12 05:15 | Joachim Pouderoux | New Issue | |
2015-01-13 04:12 | Joachim Pouderoux | Note Added: 0034074 | |
2015-01-13 04:56 | Joachim Pouderoux | Note Added: 0034075 | |
2015-01-13 04:56 | Joachim Pouderoux | Status | backlog => gatekeeper review |
2015-01-13 04:56 | Joachim Pouderoux | Resolution | open => fixed |
2015-01-13 04:56 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2015-01-13 04:56 | Joachim Pouderoux | Topic Name | => 15526_Fix_DefaultWin64InstallPath (on superbuild git) |
2015-01-22 09:52 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-01-22 09:52 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-01-22 09:52 | Utkarsh Ayachit | Note Added: 0034093 | |
2015-01-22 10:04 | Utkarsh Ayachit | Assigned To | Joachim Pouderoux => Utkarsh Ayachit |
2015-01-22 10:04 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Joachim Pouderoux |
2015-01-22 10:08 | Utkarsh Ayachit | Note Deleted: 0034093 | |
2015-06-04 17:46 | Alan Scott | Note Added: 0034485 | |
2015-06-04 17:46 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
