0015254 | VTK | Bug | public | 2015-01-11 21:45 | 2015-02-09 15:58 | ||||
Reporter | Jean-Christophe Fillion-Robin | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Target Version | 6.3.0 | Fixed in Version | 6.2.0 | ||||||
Summary | 0015254: Configuration fails with "VTK_ENABLE_KITS" ON and "VTK_RENDERING_BACKEND" set to OpenGL2 | ||||||||
Description | The error reported below happen using VTK d64654d CMake Error at Rendering/VolumeOpenGL2/CMakeLists.txt:65 (add_dependencies): add_dependencies Cannot add target-level dependencies to INTERFACE library target "vtkRenderingVolumeOpenGL2". -- Configuring incomplete, errors occurred! | ||||||||
Project | TBD | ||||||||
(0034071) Jean-Christophe Fillion-Robin (manager) 2015-01-13 00:11 |
A possible fix could be https://github.com/Slicer/VTK/commit/f5dd079959ad050a80a59727ea556102cdb27d9f [^] |
(0034089) Jean-Christophe Fillion-Robin (manager) 2015-01-19 13:39 |
Aashish suggested to add the dependency to "vtkRendering" unconditionally. The caveat is that since vtkRendering exists only when building VTK with VTK_ENABLE_KITS set to ON and vtkRenderingVolumeOpenGL2 is an interface and not a target when that same option is ON, his suggestion is not possible. It basically gives the following error: CMake Error at Rendering/VolumeOpenGL2/CMakeLists.txt:65 (add_dependencies): Cannot add target-level dependencies to non-existent target "vtkRendering". The add_dependencies works for top-level logical targets created by the add_executable, add_library, or add_custom_target commands. If you want to add file-level dependencies see the DEPENDS option of the add_custom_target and add_custom_command commands. |
(0034160) Dave DeMarle (administrator) 2015-02-05 12:07 |
We want gl2 to be a prototype in 6.2, so fix will have to come after this release. 6.2.1 is ok. |
(0034199) Ben Boeckel (Kitware) (developer) 2015-02-09 15:58 |
This has actually already been fixed: http://review.source.kitware.com/#/t/5345/ [^] |
2015-01-11 21:45 | Jean-Christophe Fillion-Robin | New Issue | |
2015-01-13 00:11 | Jean-Christophe Fillion-Robin | Note Added: 0034071 | |
2015-01-19 13:39 | Jean-Christophe Fillion-Robin | Note Added: 0034089 | |
2015-01-19 13:41 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
2015-02-05 12:07 | Dave DeMarle | Note Added: 0034160 | |
2015-02-05 12:07 | Dave DeMarle | Target Version | 6.2.0 => 6.3.0 |
2015-02-05 12:07 | Dave DeMarle | Description Updated | |
2015-02-09 15:58 | Ben Boeckel (Kitware) | Note Added: 0034199 | |
2015-02-09 15:58 | Ben Boeckel (Kitware) | Status | backlog => closed |
2015-02-09 15:58 | Ben Boeckel (Kitware) | Resolution | open => fixed |
2015-02-09 15:58 | Ben Boeckel (Kitware) | Fixed in Version | => 6.2.0 |
