0015237 | ParaView | (No Category) | public | 2015-01-05 12:32 | 2016-08-12 09:59 | ||||
Reporter | Mark Stock | ||||||||
Assigned To | Aashish Chaudhary | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015237: Immersive ParaView hangs when reading tracking data from Vrui's VRDeviceDaemon | ||||||||
Description | We are running Immersive ParaView 4.2.0 (custom build) on RHEL6.5 machine for both server and client. I can use the vrpn interface for tracking, but that only supports reading from one port number (and we need two). I am thus trying to use Vrui's VRDeviceDaemon to pass the tracking data to ParaView (because VRDeviceDaemon *can* read from both vrpn ports). After setting things up, hitting "Start" in the VR panel causes the program to seize. On the VRDeviceDaemon terminal, the last lines are: VRDeviceServer: Connecting new client from localhost, port 60884 VRDeviceServer: Waiting for client connection Killing the process results in a plethora of these errors to the ParaView server terminal: ERROR: In /opt/ParaView/dist/ParaView-v4.2.0/VTK/Common/System/vtkSocket.cxx, line 572 vtkClientSocket (0x13f9730): Socket error in call to send. Broken pipe. The same thing happens with Vrui 3.1-002 and 2.6-001. I can run "Vrui/bin/DeviceTest -t 0 localhost:3883" to see that the tracking data does indeed exist. The relevant section of my state file is: <VRConnectionManager> <VRUIConnection name="vrconn" address="localhost" port="3883"> <Tracker id="0" name="head"/> <TrackerTransform value="-1 0 0 0 0 0 1 0 0 1 0 0 0 0 0 1 "/> </VRUIConnection> </VRConnectionManager> <VRInteractorStyles> <Style class="vtkVRTrackStyle" proxyName="RenderView1" proxy="3559" property="EyeTransformMatrix"> <Tracker role="Tracker" name="vrconn.head"/> </Style> </VRInteractorStyles> This seems to be the same problem as seen here: http://public.kitware.com/pipermail/paraview/2014-February/030582.html [^] | ||||||||
Project | ParaViewVR | ||||||||
Type | crash | ||||||||
(0034069) Mark Stock (reporter) 2015-01-12 14:03 |
I didn't mean to assign the bug just now---I was looking for how to change the severity. The entire program hangs indefinitely, that seems more severe than "minor." |
(0038755) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-05 12:32 | Mark Stock | New Issue | |
2015-01-12 14:02 | Mark Stock | Assigned To | => Aashish Chaudhary |
2015-01-12 14:03 | Mark Stock | Note Added: 0034069 | |
2015-01-13 03:47 | Joachim Pouderoux | Summary | Immedsive ParaView hangs when reading tracking data from Vrui's VRDeviceDaemon => Immersive ParaView hangs when reading tracking data from Vrui's VRDeviceDaemon |
2015-01-13 03:47 | Joachim Pouderoux | Description Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038755 | |
