0015203ParaView(No Category)public2014-12-12 15:212015-09-06 12:18
ReporterAlan Scott
Assigned ToDan Lipsa
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target Version4.4Fixed in Version4.4
Summary0015203: ParaView help/ filters list issues
DescriptionPlease sort the ParaView help/ filters list.
The following filters are missing from the help list:
AMR Connectivity
AMR Contour
AMR CutPlane
AMR Dual Clip
AMR Fragment Integration
AMR Fragments Filter
Contingency Statistics
ConvertAMR Dataset to Multi-block
Descriptive Statistics
ExtractAMRBlocks
Extract Bag Plots
Extract CTH Parts
Extract Level
Extract Location
FFT of Selection Over Time
Generate Quadrature Points
Generate Quadrature Scheme Dictionary
Image Data to AMR (There are two filters listed, which is correct?)
Interpolate to Quadrature Points
Intersect Fragments
K Means
Level Scalars (Non-overlapphing AMR)
Level Scalars (Overlapping AMR)
Material Interface Filter
Multicorrective Statistics
Normal Glyphs
Particle Path
Plot Global Variables Over Time
Plot On Intersection Curves
Plot over Line
Principle Component Analysis
Resample AMR
Slice AMR data
StreakLine
The following filters are listed, but don't have a one line explination:
Annotate Global Data
Image Data to Point Set
Plot on Sorted lines
Rectalinear Data to Point Set
TagsNo tags attached.
ProjectSandia
Topic Namehelp-15203
Typeincorrect functionality
 Relationships
  Notes
(0034030)
Dan Lipsa (developer)
2015-01-08 17:12
edited on: 2015-01-12 10:27
commit 55d44e899934120caf1bfd4aebcf5f569d867981
Author: Dan Lipsa <dan.lipsa@kitware.com>
Date: Thu Jan 8 17:10:50 2015 -0500
    Add reStructured text (RST) formating to proxy documentation.
    See Calculator for an example.
    Also, sort documentation by proxy label, fix readers and writers,
    add the extension to readers and writers documentation.
    Change-Id: I74c8a96d52df858bf04af5b27951c20117a09ecd
(0034094)
2015-01-22 09:52
SUMMARY
Topics merged into master (v4.3.1-46-gc563e84):
        15246_updated_data_active_values
        allow-catalyst-tables
        cgns-plugin-string-fix
        custom_color_map_defaults_for_arrays
        fix_sphinx_icon
        internal_halo_finder
        new_cosmotools
(VTK) pvweb-document-disable-registry
        read_only_certain_halos
Topics reverted from next:
  msmpi-fix
  pvweb-add-scalar-range-controls
(0034096)
2015-01-22 10:36
This is not merged in next.
(0034105)
2015-01-23 09:52
Topics merged into master (v4.3.1-50-g71439c9):
        help-15203
(VTK) pvweb-add-scalar-range-controls
(0034248)
Alan Scott (manager)
2015-02-18 17:34
Nice. Thanks for doing this, I know it was probably a lot of mundane work.
Linux, master.
 Issue History
2014-12-12 15:21 Alan Scott New Issue
2014-12-12 15:21 Alan Scott Target Version => 4.4
2014-12-19 11:32 Dan Lipsa Status backlog => active development
2014-12-19 11:38 Dan Lipsa Assigned To => Dan Lipsa
2015-01-08 17:12 Dan Lipsa Topic Name => help-15203
2015-01-08 17:12 Dan Lipsa Note Added: 0034030
2015-01-08 17:14 Dan Lipsa Note Edited: 0034030
2015-01-09 10:21 Dan Lipsa Note Edited: 0034030
2015-01-12 10:27 Dan Lipsa Note Edited: 0034030
2015-01-12 10:28 Dan Lipsa Status active development => gatekeeper review
2015-01-22 09:52 Utkarsh Ayachit Fixed in Version => git-master
2015-01-22 09:52 Utkarsh Ayachit Status gatekeeper review => customer review
2015-01-22 09:52 Utkarsh Ayachit Note Added: 0034094
2015-01-22 10:36 Utkarsh Ayachit Status customer review => gatekeeper review
2015-01-22 10:36 Utkarsh Ayachit Resolution open => fixed
2015-01-22 10:36 Utkarsh Ayachit Note Added: 0034096
2015-01-22 10:36 Utkarsh Ayachit Status gatekeeper review => active development
2015-01-23 09:49 Utkarsh Ayachit Status active development => gatekeeper review
2015-01-23 09:52 Utkarsh Ayachit Status gatekeeper review => customer review
2015-01-23 09:52 Utkarsh Ayachit Note Added: 0034105
2015-02-18 17:34 Alan Scott Note Added: 0034248
2015-02-18 17:34 Alan Scott Status customer review => closed
2015-09-06 12:18 Utkarsh Ayachit Fixed in Version git-master => 4.4
