0015157 | ParaView | (No Category) | public | 2014-11-26 09:53 | 2015-01-02 10:43 | ||||
Reporter | Yumin Yuan | ||||||||
Assigned To | Yumin Yuan | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015157: Some Qt event player classes are missing Q_Object declaration | ||||||||
Description | A few of the Qt event players are missing Q_Object macro so that they did not have qt meta_object (moc_<class> objects) created. This breaks some Qt UI testing scripts with the changes in QtTesting repo because those changes use the class name of the event_player meta_objects when registering them with testing utility. The end result of this mis-match is that these paraview event players won't register with the testing utility, which leads to some scripts fail due to unhandled events. | ||||||||
Project | TBD | ||||||||
Topic Name | qtEvent_player_fix | ||||||||
(0033860) Utkarsh Ayachit (administrator) 2014-11-27 11:39 |
Topics merged into master (v4.2.0-153-g044be9b) 0015141_add_rotation_factor 0015144_subticks_marks_deactivation 0015146_add_SelectPoints_function_in_pvsimple 15137_fix_label_format 15148_ADIOS_require_MPI (VTK) kdtree-repr qtEvent_player_fix (VTK) update-hdf5 (VTK) vtk_20141122 |
(0033870) Alan Scott (manager) 2014-12-02 15:48 |
Developer tag in git. Closing. |
2014-11-26 09:53 | Yumin Yuan | New Issue | |
2014-11-26 09:53 | Yumin Yuan | Assigned To | => Yumin Yuan |
2014-11-26 09:54 | Yumin Yuan | Status | backlog => todo |
2014-11-26 09:54 | Yumin Yuan | Status | todo => active development |
2014-11-26 09:55 | Yumin Yuan | Topic Name | => qtEvent_player_fix |
2014-11-26 09:55 | Yumin Yuan | Status | active development => gatekeeper review |
2014-11-26 09:55 | Yumin Yuan | Fixed in Version | => git-next |
2014-11-26 09:55 | Yumin Yuan | Resolution | open => fixed |
2014-11-27 11:38 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-27 11:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-27 11:39 | Utkarsh Ayachit | Note Added: 0033860 | |
2014-12-02 15:48 | Alan Scott | Note Added: 0033870 | |
2014-12-02 15:48 | Alan Scott | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
