0015148 | ParaView | (No Category) | public | 2014-11-24 11:49 | 2015-01-02 10:43 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015148: update writer factory to ignore writers that don't work without MPI for vtkADIOSWriter | ||||||||
Description | The vtkADIOS{Reader,Writer} require MPI so adding in mpi_required to their XML proxy definitions. Also, adding in a check in vtkSMWriterFactory if the writer requires MPI and it's not initialized on the session that is doing the writing. | ||||||||
Project | TBD | ||||||||
Topic Name | 15148_ADIOS_require_MPI | ||||||||
Type | crash | ||||||||
(0033844) Andy Bauer (developer) 2014-11-25 09:16 |
commit 51e231bd320796c145b9ef613ebad6dca963598f Author: Andrew Bauer <andy.bauer@kitware.com> Date: Mon Nov 24 11:51:14 2014 -0500 Fix ADIOS reader/writer to require MPI. Setting vtkADIOSReader and vtkADIOSWriter to require MPI to be initialized in order to use. Also changing vtkSMWriterFactory to check if MPI is initialized on the session when a MPI required writer is requested. Change-Id: I89f7b8314eae9f2ba2450b17450348a39a956317 |
(0033858) Utkarsh Ayachit (administrator) 2014-11-27 11:39 |
Topics merged into master (v4.2.0-153-g044be9b) 0015141_add_rotation_factor 0015144_subticks_marks_deactivation 0015146_add_SelectPoints_function_in_pvsimple 15137_fix_label_format 15148_ADIOS_require_MPI (VTK) kdtree-repr qtEvent_player_fix (VTK) update-hdf5 (VTK) vtk_20141122 |
2014-11-24 11:49 | Andy Bauer | New Issue | |
2014-11-24 11:49 | Andy Bauer | Assigned To | => Andy Bauer |
2014-11-24 11:49 | Andy Bauer | Status | backlog => todo |
2014-11-24 11:49 | Andy Bauer | Status | todo => active development |
2014-11-25 09:16 | Andy Bauer | Topic Name | => 15148_ADIOS_require_MPI |
2014-11-25 09:16 | Andy Bauer | Note Added: 0033844 | |
2014-11-25 09:16 | Andy Bauer | Status | active development => gatekeeper review |
2014-11-25 09:16 | Andy Bauer | Fixed in Version | => git-next |
2014-11-25 09:16 | Andy Bauer | Resolution | open => fixed |
2014-11-27 11:38 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-27 11:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-27 11:39 | Utkarsh Ayachit | Note Added: 0033858 | |
2014-12-01 12:37 | Andy Bauer | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
