0015127 | ParaView | (No Category) | public | 2014-11-13 21:48 | 2015-07-09 22:02 | ||||
Assigned To | Dan Lipsa | ||||||||
Product Version | 4.2 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.3 | ||||||
Summary | 0015127: t_index variable not available, Mode Shapes | ||||||||
Description | My user did a good enough job explaining this bug, I will just use his verbiage. Here it is: Hello, Attached is an exodus file that I'm having trouble with in ParaView 4.2.0, 64-bit, RHEL5. The problem is that the "t_index" variable is not available when I check the "Has Mode Shapes" option. I am trying to add an annotation that say something like "Eigenvalue is : EigenFrequency[ index ]", but there I can't seem to find what variable refers to the current "Mode Index." If I uncheck the "Has Mode Shapes" option, then the variable t_index works and I can just do "EigenFrequency[t_index]" to get the frequency to be annotated. Steps to reproduce: 1) open "example_beam-eig.g", load all variables. 2) Create an "PythonAnnotation" filter. 3) Select "Field Data" 4) Enter "EigenFrequency[t_index]" in the "Expression" field. 5) Apply. Annotation should show up as "0.0" 6) Increase to time step 7, it should read "1985.697" 7) Go back to top of pipeline and select "Has Mode Shapes" check box. 8) ---> ERROR: name t_index is not defined Ok, well that doesn't work. Let's try the "AnnotateGlobalData" filter. 9) Add a "AnnotateGlobalData" filter. 9a) "Select Arrays" --> EigenFrequency 9b) "Prefix" --> Value is: 9c) Apply It will show the entire vector -- which is not useful. 10) Uncheck "Has Mode Shapes" The AnnotateGlobalData filter will just show a single value -- which is useful. It seems like what is missing is a "Mode Shape Index" variable. Does this exist? If so, it doesn't seem like it's being properly referenced in the annotation filters. But at least I might be able to use a Python Annotation filter to get around this if it does exist. | ||||||||
Additional Information | VTK commit ========== commit 9c7135b9432d6f2cd2f4f3e03dd881528fb60b38 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Dec 4 16:04:26 2014 -0500 Add data_index to Exodus driver data_index[0] represents the time step (t_index) if HasModeShapes=0 or ModeShape otherwise. This commit also removes an unused variable. Change-Id: I08716d6c904aa18eb5b6163a6d394e3c47bcb138 ParaView commit =============== commit ccbcf3de1d18d4077fd1c0fcc5a6902333e03898 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Dec 4 16:23:54 2014 -0500 Update VTK to: Add data_index to Exodus driver Change-Id: I030d1a2b089a7331e79f868291d9fee947203f1b | ||||||||
Project | Sandia | ||||||||
Topic Name | exodus-15127 | ||||||||
Attached Files | example_beam-eig.g [^] (399,788 bytes) 2014-11-13 21:50 | ||||||||
(0033918) Utkarsh Ayachit (administrator) 2014-12-10 07:58 |
--------------------------------------------- Topics merged into master (v4.2.0-234-g5082012): settings-15161 (BUG 0015127 fix seems to already have been merged in git/master) --------------------------------------------- Topics reverted from next: python-calc-15125 sorting-15130 |
(0033941) Alan Scott (manager) 2014-12-11 17:51 |
Dan, Talked to Utkarsh, and what you have below works correctly. Two modifications, if you don't mind. * Please change the variable name from data_index[] to mode_shapes[]. If this seems wrong, please discuss with Utkarsh, and I will gladly go with whatever you two decide. * Please add documentation to the Exodus library, giving an example of using this array. In other words, how does a user find out the name of this array? Once again, ping Utkarsh to flesh out this request if needed. Thanks! Alan |
(0033987) Dan Lipsa (developer) 2014-12-19 10:28 edited on: 2014-12-19 10:28 |
VTK === commit 084b0bb13545fbd3e5c3f937d4a69416cf8492ef Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Dec 15 11:05:29 2014 -0500 Rename data_index to mode_shape in Exodus reader. Field variable mode_shape[0] represents the time step (t_index) if HasModeShapes is not set or the ModeShape otherwise. Change-Id: Id25aab00dfe04ae142a477650cbc3a17c9b11254 ParaView ======== commit f44839d3931b98d54bca2c1365f993af147ab1d7 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Dec 15 11:13:39 2014 -0500 Move VTK: Rename data_index to mode_shape in Exodus reader Change-Id: I431bf9862dde8495b0f30bb33be2f92486806821 commit f107463f3959405efa6f5b94d43fee731a21d684 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Dec 15 11:11:59 2014 -0500 Add documentation about mode_shape to the Exodus reader. Change-Id: Iedbb901685be021f976ef17ed28d6f8fb31cb148 |
(0034000) Utkarsh Ayachit (administrator) 2014-12-23 07:47 |
SUMMARY --------------------------------------------- Topics merged into master (v4.2.0-339-g3d6f539): (VTK) 14539-can-crash 15073_fix_ResetCamera 6657_add_outside_range_colors (VTK) KW00001499_ColorByFieldData add_cgns_plugin_test camera-9503 cfapi-null-logic (VTK) exodus-15127 fix-dashboard-warning h5part-15215 mangle-pvbatch-test-names (VTK) opengl2_updates pvweb-support-multiple-data-directories revert-cfapi-deprecation-fixes support_custom_link_path_setting update-catalyst-20141215 webvisualizer-add-tooltips |
(0034731) Alan Scott (manager) 2015-07-09 21:25 |
This now works local server, but fails remote server. Local server works as follows when you input the string into the PythonAnnotation filter. ModeNumber[] (Result is: (1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ) ) ModeNumber[1] (Result is: 2.0) ModeNumber[t_index] (Result is: 1.0 (for the first timestep)) Remote server (8 ranks) ModeNumber[] (Result is: (error)) ModeNumber[1] (Result is: (error)) ModeNumber[t_index] (Result is: (error)) |
(0034735) Alan Scott (manager) 2015-07-09 22:02 |
My bad. I have a bad remote server (numpy is bad). Tested local server, Linux, master. Looks good. Closing. |
2014-11-13 21:48 | Alan Scott | New Issue | |
2014-11-13 21:50 | Alan Scott | File Added: example_beam-eig.g | |
2014-11-13 21:50 | Alan Scott | Target Version | => bug_fix |
2014-11-14 11:14 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2014-12-02 16:15 | Dan Lipsa | Status | backlog => active development |
2014-12-04 16:22 | Dan Lipsa | Topic Name | => exodus-15127 |
2014-12-04 16:22 | Dan Lipsa | Additional Information Updated | |
2014-12-04 16:26 | Dan Lipsa | Additional Information Updated | |
2014-12-08 09:29 | Dan Lipsa | Status | active development => gatekeeper review |
2014-12-10 07:58 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-12-10 07:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-10 07:58 | Utkarsh Ayachit | Note Added: 0033918 | |
2014-12-11 17:51 | Alan Scott | Note Added: 0033941 | |
2014-12-11 17:51 | Alan Scott | Status | customer review => todo |
2014-12-15 11:20 | Dan Lipsa | Additional Information Updated | |
2014-12-15 11:21 | Dan Lipsa | Status | todo => active development |
2014-12-16 09:30 | Dan Lipsa | Status | active development => gatekeeper review |
2014-12-19 09:57 | Dan Lipsa | Status | gatekeeper review => active development |
2014-12-19 10:28 | Dan Lipsa | Note Added: 0033987 | |
2014-12-19 10:28 | Dan Lipsa | Additional Information Updated | |
2014-12-19 10:28 | Dan Lipsa | Note Edited: 0033987 | |
2014-12-20 09:15 | Dan Lipsa | Status | active development => gatekeeper review |
2014-12-23 07:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-23 07:47 | Utkarsh Ayachit | Note Added: 0034000 | |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-07-09 21:25 | Alan Scott | Note Added: 0034731 | |
2015-07-09 21:25 | Alan Scott | Status | customer review => todo |
2015-07-09 21:25 | Alan Scott | Target Version | 4.3 => 4.4 |
2015-07-09 22:02 | Alan Scott | Note Added: 0034735 | |
2015-07-09 22:02 | Alan Scott | Status | todo => closed |
2015-07-09 22:02 | Alan Scott | Resolution | open => fixed |
