0015104 | ParaView | (No Category) | public | 2014-11-05 09:30 | 2015-01-11 08:14 | ||||
Reporter | Andy Bauer | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0015104: catalyst scripts is adding in WriteFrequency output for writers | ||||||||
Description | A potential fix is at http://review.source.kitware.com/#/c/17864/1 [^] Steps to reproduce: load the catalyst script generator plugin load a file create a catalyst writer for that file and change File Name and Write Frequency export the script The writer in the generated script will try to set both FileName and WriteFrequency, e.g.: parallelImageDataWriter1.FileName = 'filena33me_%t.pvti' parallelImageDataWriter1.WriteFrequency = 133 | ||||||||
Project | Catalyst | ||||||||
Topic Name | 15104_fix_catalyst_writers | ||||||||
(0033733) Utkarsh Ayachit (administrator) 2014-11-05 16:47 |
commit 8e56e935a171acf6b96573066a7c527ef7b5217a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Nov 5 16:46:48 2014 -0500 BUG 0015104: Fix writers exported in catalyst scripts. Writers exported to catalyst script should not include properties like WriteFrequency, FileName. Fixed that. Change-Id: Iebd7859d5b957c614ee15d453e5f6505e5f7b56f |
(0033742) Utkarsh Ayachit (administrator) 2014-11-06 08:44 |
Topics merged into master: 14845_reset_color_map 15053_fix_coloring_with_missing_arrays 15085_fix_install_rules_for_catalyst 15107_catalyst_rendering_edition opengl2-backend (VTK) vtk_master_20141105 |
(0033746) Andy Bauer (developer) 2014-11-06 09:27 |
It looks like this branch didn't make it into master yet. I don't see any change to cpstate.py and that's where I thought the change was supposed to go. |
(0033747) Utkarsh Ayachit (administrator) 2014-11-06 10:02 |
You're right. Oops :). |
(0033749) Utkarsh Ayachit (administrator) 2014-11-06 14:55 |
Merge topic '15104_fix_catalyst_writers' 8e56e935 BUG 0015104: Fix writers exported in catalyst scripts. |
(0033751) Alan Scott (manager) 2014-11-06 15:58 |
How does a person "Export Script"? I don't see the command. |
(0033754) Andy Bauer (developer) 2014-11-06 16:10 |
You need to load the CatalystScriptGenerator plugin first. See section 2 in http://www.paraview.org/Wiki/images/4/48/CatalystUsersGuide.pdf [^] |
2014-11-05 09:30 | Andy Bauer | New Issue | |
2014-11-05 09:30 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2014-11-05 09:31 | Utkarsh Ayachit | Target Version | => bug_fix |
2014-11-05 16:47 | Utkarsh Ayachit | Topic Name | => 15104_fix_catalyst_writers |
2014-11-05 16:47 | Utkarsh Ayachit | Note Added: 0033733 | |
2014-11-05 16:47 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-05 16:47 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-11-05 16:47 | Utkarsh Ayachit | Resolution | open => fixed |
2014-11-06 08:44 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-06 08:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-06 08:44 | Utkarsh Ayachit | Note Added: 0033742 | |
2014-11-06 09:27 | Andy Bauer | Note Added: 0033746 | |
2014-11-06 09:27 | Andy Bauer | Status | customer review => todo |
2014-11-06 09:46 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-11-06 10:02 | Utkarsh Ayachit | Note Added: 0033747 | |
2014-11-06 14:55 | Utkarsh Ayachit | Note Added: 0033749 | |
2014-11-06 14:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-06 15:58 | Alan Scott | Note Added: 0033751 | |
2014-11-06 16:10 | Andy Bauer | Note Added: 0033754 | |
2014-11-12 10:19 | Andy Bauer | Status | customer review => closed |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 22393864 |
2015-01-11 08:14 | Dan Lipsa | Source_changeset_attached | => ParaView master d20bd066 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 33e1c336 |
2015-01-11 08:14 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8e56e935 |
