0015073 | ParaView | (No Category) | public | 2014-10-24 14:17 | 2015-06-04 18:31 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.2 | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015073: Python trace: ResetCamera() method generated from Zoom to Data produces called with too many arguments | ||||||||
Description | Steps to reproduce: - Paraview, built-in server - Tools -> Start Trace, default options - Sources -> Sphere - Click 'Zoom to Data' button - Tools -> Stop Trace - Save generated script - Tools -> Python Shell - Click Run Script, select saved generated script An error occurs: Traceback (most recent call last): File "<string>", line 26, in <module> TypeError: __call__() takes exactly 1 argument (7 given) The offending call is renderView1.ResetCamera(-0.999689161777, 0.999689161777, -0.999689161777, 0.999689161777, -1.0, 1.0) | ||||||||
Project | TBD | ||||||||
Topic Name | 15073_fix_ResetCamera | ||||||||
(0033668) Utkarsh Ayachit (administrator) 2014-10-26 11:50 |
The problem is not with the trace, but with the wrapping or something. This is intended to call vtkSMRenderViewProxy::ResetCamera[1] method. http://www.paraview.org/ParaView3/Doc/Nightly/www/cxx-doc/classvtkSMRenderViewProxy.html#ac6c92a7f4df8402d0b6a6e28a4881ed7 [^] |
(0033994) Cory Quammen (developer) 2014-12-22 23:19 |
commit be448fbaed4bb3f6581d36062632d8f5f8086a7f Cory Quammen <cory.quammen@kitware.com> Mon, 22 Dec 2014 21:50:30 +0000 (16:50 -0500) Removed unneeded ResetCamera property from RenderView proxy Fixed command invocation to method that works now that the RenderView property is gone. Change-Id: Icfb374882eaa47a5646cac809077aa40b3b26f08 |
(0033997) Utkarsh Ayachit (administrator) 2014-12-23 07:47 |
SUMMARY --------------------------------------------- Topics merged into master (v4.2.0-339-g3d6f539): (VTK) 14539-can-crash 15073_fix_ResetCamera 6657_add_outside_range_colors (VTK) KW00001499_ColorByFieldData add_cgns_plugin_test camera-9503 cfapi-null-logic (VTK) exodus-15127 fix-dashboard-warning h5part-15215 mangle-pvbatch-test-names (VTK) opengl2_updates pvweb-support-multiple-data-directories revert-cfapi-deprecation-fixes support_custom_link_path_setting update-catalyst-20141215 webvisualizer-add-tooltips |
(0034488) Alan Scott (manager) 2015-06-04 18:31 |
Tested master, Linux, local server. |
2014-10-24 14:17 | Cory Quammen | New Issue | |
2014-10-24 14:17 | Cory Quammen | Assigned To | => Utkarsh Ayachit |
2014-10-26 11:50 | Utkarsh Ayachit | Note Added: 0033668 | |
2014-10-26 11:51 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Cory Quammen |
2014-12-22 23:19 | Cory Quammen | Topic Name | => 15073_fix_ResetCamera |
2014-12-22 23:19 | Cory Quammen | Note Added: 0033994 | |
2014-12-22 23:19 | Cory Quammen | Status | backlog => gatekeeper review |
2014-12-22 23:19 | Cory Quammen | Fixed in Version | => 4.3 |
2014-12-22 23:19 | Cory Quammen | Resolution | open => fixed |
2014-12-23 07:47 | Utkarsh Ayachit | Fixed in Version | 4.3 => git-master |
2014-12-23 07:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-23 07:47 | Utkarsh Ayachit | Note Added: 0033997 | |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-06-04 18:31 | Alan Scott | Note Added: 0034488 | |
2015-06-04 18:31 | Alan Scott | Status | customer review => closed |
