0015070 | ParaView | (No Category) | public | 2014-10-24 00:40 | 2016-08-12 09:59 | ||||
Product Version | 4.2 | ||||||||
Summary | 0015070: Lighting bug | ||||||||
Description | This is a lighting bug that is really hard to replicate, and I am not even sure this is the main one. Anyway, it needs to be fixed. When you use ParaView, all of a sudden colors go bad. The only way to correct this is to close ParaView, or turn on an additional headlight. * Linux, 4.2.0, local server. No .config files (I deleted them). * Open can.exo. All vars on. Apply. * Color by ACCL. Notice the colors of the plate bottom on screen. * Open the color editor. Click "Interpret Values as Categories", turning it on. Now, click "Interpret Values as Categories" once more, turning it off. <<Bug>> The plate will now have a very dark, red and black appearance. This needs to be corrected. | ||||||||
Project | Sandia | ||||||||
(0033688) Utkarsh Ayachit (administrator) 2014-11-03 14:46 |
Work around is to "modify" the reader, e.g change array selection. The bug it not a lighting bug, but the fact the color mapping is not happening again once the "interpret values as colors" is unchecked. |
(0038691) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-24 00:40 | Alan Scott | New Issue | |
2014-11-03 14:46 | Utkarsh Ayachit | Note Added: 0033688 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038691 | |
