0015043 | ParaView | (No Category) | public | 2014-10-10 09:30 | 2015-01-02 10:45 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015043: QMake executable is not being set in ParaView/CMake/UseParaView.cmake | ||||||||
Description | Reported by Jim.Eliot@awe.co.uk on the paraview mailing list: I am trying to build a file reader plugin against ParaView 4.2.0 and have been experiencing some difficulties. Qt is not found by cmake during the build process causing it to fail. To illustrate the issue, I created the following simplified CMakeLists.txt file: CMAKE_MINIMUM_REQUIRED FIND_PACKAGE(ParaView REQUIRED) INCLUDE(${PARAVIEW_USE_FILE}) When I call cmake with ParaView_DIR pointing at my 4.1.0 build Qt is found, but with 4.2.0 Qt is NOT found. ParaView was built using Superbuild and Qt was built as part of that process. Should Qt be detected from ParaViewConfig.cmake? Is this a change in behaviour between 4.1.0 and 4.2.0? Do I somehow need to specify the location of Qt manually? | ||||||||
Project | TBD | ||||||||
Topic Name | 15043_add_qmake_variable_back | ||||||||
(0033622) Cory Quammen (developer) 2014-10-10 09:31 |
This was accidentally changed when support for Qt5 was added in commit eed7ccd3f7e804fed3864fcbe54fbd6958e63b41. In ParaView/CMake/UseParaView.cmake, adding set(QT_QMAKE_EXECUTABLE ${PARAVIEW_QT_QMAKE_EXECUTABLE}) just before the lines with find_package(Qt4) fixes the problem. |
(0033630) Cory Quammen (developer) 2014-10-10 13:49 |
commit 2a85f0c4c14a32b345e09833e439b3cced2976af Author: Cory Quammen <cory.quammen@kitware.com> Date: Fri Oct 10 13:39:16 2014 -0400 Added back setting of QT_QMAKE_EXECUTABLE in UseParaView.cmake This was inadvertently removed in commit eed7ccd3f7e804fed3864fcbe54fbd6958e63b41 Change-Id: I46ddec948e892cb507bf34549ae62b1b530e345e |
(0033650) Utkarsh Ayachit (administrator) 2014-10-15 10:08 |
Topics merged into master: 15025_fix_annotations 15035_reverse_connections_dsrs 15043_add_qmake_variable_back 15044_update_example_plugins cmake-cmp0053-warnings live-breakpoint pv-plot-bar-lut visible_range |
(0033768) Alan Scott (manager) 2014-11-06 19:27 |
Trusting fixed. Closing. |
2014-10-10 09:30 | Cory Quammen | New Issue | |
2014-10-10 09:30 | Cory Quammen | Assigned To | => Cory Quammen |
2014-10-10 09:31 | Cory Quammen | Note Added: 0033622 | |
2014-10-10 09:31 | Cory Quammen | Status | backlog => active development |
2014-10-10 13:49 | Cory Quammen | Topic Name | => 15043_add_qmake_variable_back |
2014-10-10 13:49 | Cory Quammen | Note Added: 0033630 | |
2014-10-10 13:49 | Cory Quammen | Status | active development => gatekeeper review |
2014-10-10 13:49 | Cory Quammen | Fixed in Version | => 4.2.1 |
2014-10-10 13:49 | Cory Quammen | Resolution | open => fixed |
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | 4.2.1 => git-master |
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033650 | |
2014-11-06 19:27 | Alan Scott | Note Added: 0033768 | |
2014-11-06 19:27 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
