0015035 | ParaView | (No Category) | public | 2014-10-07 11:40 | 2015-01-02 10:45 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.2 | ||||||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015035: Reverse connections don't work with render and data servers | ||||||||
Description | Server commands run: pvdataserver -rc -ch=localhost pvrenderserver -rc -ch=localhost The host name appears as the empty string in the reported error message. Also, the client reports it is listening for two separate connections on the same port, which doesn't seem to be correct. | ||||||||
Project | TBD | ||||||||
Topic Name | 15035_reverse_connections_dsrs | ||||||||
(0033610) Cory Quammen (developer) 2014-10-07 13:25 |
commit 43bf1158fe995152aa9c79c2715b10166c137a5c Author: Cory Quammen <cory.quammen@kitware.com> Date: Tue Oct 7 12:39:26 2014 -0400 BUG 15035: Fix reverse connections for render/data servers URLs were not being parsed or generated correctly in a couple places when setting up a reverse connection with render and data servers. Change-Id: I4445573847184298387c5e61c32cd949080fd6dd |
(0033649) Utkarsh Ayachit (administrator) 2014-10-15 10:08 |
Topics merged into master: 15025_fix_annotations 15035_reverse_connections_dsrs 15043_add_qmake_variable_back 15044_update_example_plugins cmake-cmp0053-warnings live-breakpoint pv-plot-bar-lut visible_range |
(0033770) Alan Scott (manager) 2014-11-06 20:08 |
Appears fixed to me. Please reopen if it isn't fixed, and I didn't test it properly. Tested Linux, master. |
2014-10-07 11:40 | Cory Quammen | New Issue | |
2014-10-07 11:40 | Cory Quammen | Assigned To | => Cory Quammen |
2014-10-07 13:25 | Cory Quammen | Topic Name | => 15035_reverse_connections_dsrs |
2014-10-07 13:25 | Cory Quammen | Note Added: 0033610 | |
2014-10-07 13:25 | Cory Quammen | Status | backlog => gatekeeper review |
2014-10-07 13:25 | Cory Quammen | Fixed in Version | => 4.2.1 |
2014-10-07 13:25 | Cory Quammen | Resolution | open => fixed |
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | 4.2.1 => git-master |
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033649 | |
2014-11-06 20:08 | Alan Scott | Note Added: 0033770 | |
2014-11-06 20:08 | Alan Scott | Status | customer review => closed |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
