0015031 | ParaView | (No Category) | public | 2014-10-06 04:21 | 2015-09-06 12:18 | ||||
Reporter | Joachim Pouderoux | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Product Version | 4.3 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015031: Multicore mode does not work with PV >= 4.2 and <= 4.3.1 | ||||||||
Description | Tested with official build of ParaView 4.3.1 under Win64. Start ParaView. Go in the Settings window. In General table, enable the "Enable multicore support for data processing." Set 4 or 8 as maximum number of cores. Apply. OK. Restart ParaView. Create a Wavelet source, choose Surface representation. You cannot choose the vtkProcessId array. In About panel, the Connection information says that there is no Remote Connection. Indeed at loading ParaView, no mpirun seems to be done in background. | ||||||||
Project | TBD | ||||||||
Topic Name | 15031_fix_multicore_mode | ||||||||
Relationships | ||||||
(0034098) Joachim Pouderoux (developer) 2015-01-22 13:04 |
Change Ic95d40cc: Fix the multicore mode which was broken since 4.2 2 reasons made the multicore mode not working anymore: - the 2 related properties were renamed - their values were not saved in QSettings anymore. Change-Id: Ic95d40cc10de4345124589743c992293c2d70f88 http://review.source.kitware.com/#/c/18930/ [^] |
(0034125) Utkarsh Ayachit (administrator) 2015-01-29 08:06 |
SUMMARY --------------------------------------------- Topics merged into master (v4.3.1-83-gf35be3b): 14953_fix_Esc_key_in_settings_dialog 14957_fix_settings_segfault 15031_fix_multicore_mode 15283_fix_camera_settings_importation 15293-guard-interactive-rendering bag-plot cosmotools-filters-xml fix_mpi_link_issues (VTK) output-window-15240 (VTK) pvweb-loadsave-state-and-save-data pvweb-merge-sources-filters |
(0034264) Utkarsh Ayachit (administrator) 2015-02-20 09:30 |
Tested with v4.3.1-164-g7158a0b. Works as expected now for me. |
(0034507) Alan Scott (manager) 2015-06-04 20:17 |
Tested using Kitware nightly build. Windows, master, local server. Had to use ProcessId Scalars. Worked correctly. |
2014-10-06 04:21 | Joachim Pouderoux | New Issue | |
2014-10-13 16:55 | Joachim Pouderoux | Relationship added | has duplicate 0015042 |
2015-01-22 05:49 | Joachim Pouderoux | Priority | normal => high |
2015-01-22 05:49 | Joachim Pouderoux | Reproducibility | have not tried => always |
2015-01-22 05:49 | Joachim Pouderoux | Product Version | 4.2 => 4.3 |
2015-01-22 05:49 | Joachim Pouderoux | Target Version | => git-master |
2015-01-22 05:49 | Joachim Pouderoux | Description Updated | |
2015-01-22 05:49 | Joachim Pouderoux | Summary | Multicore mode does not work anymore => Multicore mode does not work since PV 4.2 |
2015-01-22 06:00 | Joachim Pouderoux | Summary | Multicore mode does not work since PV 4.2 => Multicore mode does not work with PV >= 4.2 and <= 4.3.1 |
2015-01-22 12:59 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2015-01-22 12:59 | Joachim Pouderoux | Status | backlog => active development |
2015-01-22 13:03 | Joachim Pouderoux | Topic Name | => 15031_fix_multicore_mode |
2015-01-22 13:04 | Joachim Pouderoux | Note Added: 0034098 | |
2015-01-23 09:54 | Joachim Pouderoux | Status | active development => gatekeeper review |
2015-01-23 09:54 | Joachim Pouderoux | Resolution | open => fixed |
2015-01-23 11:42 | Joachim Pouderoux | Product Version | 4.3 => 4.4 |
2015-01-23 11:42 | Joachim Pouderoux | Product Version | 4.4 => 4.3 |
2015-01-23 11:42 | Joachim Pouderoux | Target Version | git-master => 4.4 |
2015-01-29 08:06 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-01-29 08:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-01-29 08:06 | Utkarsh Ayachit | Note Added: 0034125 | |
2015-02-20 09:30 | Utkarsh Ayachit | Note Added: 0034264 | |
2015-06-04 20:17 | Alan Scott | Note Added: 0034507 | |
2015-06-04 20:17 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
