0015025 | ParaView | (No Category) | public | 2014-10-01 21:01 | 2015-06-04 18:39 | ||||
Target Version | Fixed in Version | 4.3 | |||||||
Summary | 0015025: Toggling annotation text visibility in Catalyst/batch doesn't work. | ||||||||
Description | Play the attached text with (a) pvpython, (b) parallel pvbatch, and (c) parallel pvbatch -sym. Each prompt prints the expect visibility state for the text annotation. If works as expected in (a). In (b) and (c), once hidden, the text annotation never shows up again. | ||||||||
Project | LANL | ||||||||
Topic Name | 15025_fix_annotations | ||||||||
Attached Files | annotation.py [^] (622 bytes) 2014-10-01 21:01 | ||||||||
(0033636) Utkarsh Ayachit (administrator) 2014-10-14 17:54 |
commit 512137a3cc33e91c8cf4000952715f59dfc6f9dd Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Oct 14 17:51:09 2014 -0400 BUG 0015025: Fix toggling of text annotations. Text annotations (and other widgets) didn't work property in parallel batch mode. The problem resulted from the fact that the "CurrentRenderer" on the 3D widget was getting unset by logic in vtkAbstractWidget. A good way of avoiding that is to set the DefaultRenderer on the widget-representation. Updated vtk3DWidgetRepresentation accordingly. Also added a test (AnnotationVisibility). Change-Id: I0786cceed56ad9de682638ef675511cf088fb77b |
(0033648) Utkarsh Ayachit (administrator) 2014-10-15 10:08 |
Topics merged into master: 15025_fix_annotations 15035_reverse_connections_dsrs 15043_add_qmake_variable_back 15044_update_example_plugins cmake-cmp0053-warnings live-breakpoint pv-plot-bar-lut visible_range |
(0034494) Alan Scott (manager) 2015-06-04 18:39 |
Old bug waiting in customer review. Closing. |
2014-10-01 21:01 | Utkarsh Ayachit | New Issue | |
2014-10-01 21:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-10-01 21:01 | Utkarsh Ayachit | File Added: annotation.py | |
2014-10-14 17:54 | Utkarsh Ayachit | Topic Name | => 15025_fix_annotations |
2014-10-14 17:54 | Utkarsh Ayachit | Note Added: 0033636 | |
2014-10-14 17:54 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-10-14 17:54 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-10-14 17:54 | Utkarsh Ayachit | Resolution | open => fixed |
2014-10-15 10:08 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-10-15 10:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-10-15 10:08 | Utkarsh Ayachit | Note Added: 0033648 | |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master c4df6b41 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 512137a3 |
2015-06-04 18:39 | Alan Scott | Note Added: 0034494 | |
2015-06-04 18:39 | Alan Scott | Status | customer review => closed |
