0014997 | VTK | (No Category) | public | 2014-09-16 07:53 | 2014-10-05 18:43 | ||||
Reporter | Andrei Terechko | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Product Version | 6.0.0 | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0014997: Incorrect 'num' passed to Swap*{BE,LE}Range in CommonCoreCxx-otherByteSwap test | ||||||||
Description | In the vtkCommonCoreCxxTests-otherByteSwap test various function calls manipulate memory that hasn't been completely initialized. For example, Common/Core/Testing/Cxx/otherByteSwap.cxx contains a call to vtkByteSwap::Swap2BERange(): char cword[1024]; // ... (some other vars and tests) memcpy (cword, "abcdefgh", 8); vtkByteSwap::Swap2BERange(cword,8); In Common/Core/vtkByteSwap.h the declaration of Swap2BERange looks like this: // Swap a block of 2-, 4-, or 8-byte segments for storage as Big Endian. static void Swap2BERange(void* p, size_t num); static void Swap4BERange(void* p, size_t num); static void Swap8BERange(void* p, size_t num); What goes wrong is that apparently num in these functions refers to the number of segments, while the test uses it at the number of bytes. Indeed, after a few function calls the following code is invoked with template argument T equal to short: template <class T> inline void vtkByteSwapRange(T* first, size_t num) { // Swap one value at a time. T* last = first + num; for(T* p=first; p != last; ++p) { vtkByteSwapper<sizeof(T)>::Swap(reinterpret_cast<char*>(p)); } } Then, variable last is assigned to first+num*sizeof(short), which means in this case that the swap operation reads from 8 uninitialized bytes of the cword char array. An upcoming dynamic verification tool from Vector Fabrics found this error in the VTK test-suite. Below is the tool's output, including the stack trace for one of the incorrect invocations: [M0203] Read(s) from uninitialized stack object detected: the read in function vtkByteSwapper<2ul>::Swap at /data/peter/gits/VTK-master/Common/Core/vtkByteSwap.cxx:43 called from function vtkByteSwapRange<short> at /data/peter/gits/VTK-master/Common/Core/vtkByteSwap.cxx:75 called from function vtkByteSwapBERange<short> at /data/peter/gits/VTK-master/Common/Core/vtkByteSwap.cxx:193 called from function vtkByteSwap::SwapBERange at /data/peter/gits/VTK-master/Common/Core/vtkByteSwap.cxx:240 called from function vtkByteSwap::Swap2BERange at /data/peter/gits/VTK-master/Common/Core/vtkByteSwap.cxx:298 called from function TestByteSwap at /data/peter/gits/VTK-master/Common/Core/Testing/Cxx/otherByteSwap.cxx:57 called from function otherByteSwap at /data/peter/gits/VTK-master/Common/Core/Testing/Cxx/otherByteSwap.cxx:160 called from function main at /data/peter/gits/VTK-master/build/Common/Core/Testing/Cxx/vtkCommonCoreCxxTests.cxx:372 called from function _entry performed 1 access(es) of size 1 at an offset of 8 bytes from the start of the stack object of size 1024 allocated as `cword' in function TestByteSwap at /data/peter/gits/VTK-master/Common/Core/Testing/Cxx/otherByteSwap.cxx:32 called from function otherByteSwap at /data/peter/gits/VTK-master/Common/Core/Testing/Cxx/otherByteSwap.cxx:160 called from function main at /data/peter/gits/VTK-master/build/Common/Core/Testing/Cxx/vtkCommonCoreCxxTests.cxx:372 called from function _entry A possible patch fixing the incorrect invocations is attached. Platform: $ uname -a Linux andrei 3.5.0-54-generic #81~precise1-Ubuntu SMP Tue Jul 15 04:02:22 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux Affected versions: release 6.1.0 and the current development branch with the latest commit a5f46aff1efca6087b12853f22551273001fc4a6 at the time of writing | ||||||||
Tags | hackaton | ||||||||
Project | TBD | ||||||||
Attached Files | VTK-byteswap-num-too-high-in-test-case.patch [^] (2,151 bytes) 2014-09-16 07:53 [Show Content] | ||||||||
(0033508) Ben Boeckel (Kitware) (developer) 2014-10-02 14:30 |
Patch pushed to Gerrit with minor changes to update the output strings as well. http://review.source.kitware.com/#/t/4777/ [^] |
(0033588) Cory Quammen (developer) 2014-10-05 18:43 |
Fixed in commit dd542c6ebd2b52223b7518c53be21bb9372f8a79 Author: Ben Boeckel <ben.boeckel@kitware.com> Date: Thu Oct 2 14:28:35 2014 -0400 otherByteSwap: fix calls for byteswapping Patch submitted by Andrei Terechko. Slightly modified to match the updated calls with the output. Change-Id: Iecbf06e9c39b7d67310b0175d63719eba907c1f6 |
2014-09-16 07:53 | Andrei Terechko | New Issue | |
2014-09-16 07:53 | Andrei Terechko | File Added: VTK-byteswap-num-too-high-in-test-case.patch | |
2014-09-30 08:38 | Bill Lorensen | Tag Attached: hackaton | |
2014-09-30 08:39 | Bill Lorensen | Assigned To | => Bill Lorensen |
2014-09-30 08:39 | Bill Lorensen | Status | backlog => tabled |
2014-10-01 12:40 | Berk Geveci | Status | tabled => backlog |
2014-10-02 14:30 | Ben Boeckel (Kitware) | Assigned To | Bill Lorensen => Ben Boeckel (Kitware) |
2014-10-02 14:30 | Ben Boeckel (Kitware) | Note Added: 0033508 | |
2014-10-02 14:30 | Ben Boeckel (Kitware) | Status | backlog => gerrit review |
2014-10-05 18:43 | Cory Quammen | Note Added: 0033588 | |
2014-10-05 18:43 | Cory Quammen | Status | gerrit review => closed |
2014-10-05 18:43 | Cory Quammen | Resolution | open => fixed |
2014-10-05 18:43 | Cory Quammen | Fixed in Version | => 6.2.0 |
