0014994 | ParaView | (No Category) | public | 2014-09-11 15:41 | 2015-01-11 08:15 | ||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014994: Parallel pvbatch fails with Text() | ||||||||
Description | The following Python script raises errors when run as > mpirun -np 2 ./bin/pvbatch sample.py # sample.py from paraview.simple import * CreateRenderView() Text(Text="A") Show() v = Render() | ||||||||
Project | LANL | ||||||||
Topic Name | fix_text_source | ||||||||
(0033325) Utkarsh Ayachit (administrator) 2014-09-11 15:45 |
commit ba5698a63344be04e1f07d195e67b16b5add4c72 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Sep 11 15:42:12 2014 -0400 BUG 0014994. Fix issue with text source/representation in parallel. With changes to the pipeline, vtkPVTextSource was only getting called on the root-node. Hence text was not available on satellites. vtkTextSourceRepresentation assumed that text was available on all nodes to avoid redistribution of data. Hence we failed with missing text errors when rendering on satellites. Fixed that by making sure that vtkPVTextSource gets executed on all ranks. Also fixed vtkTextSourceRepresentation to not raise errors when empty text is set as text. Update UserTransformOnRepresentation test to test text sources in batch mode. Change-Id: I049a6b94df8e3010d3eda8c31afa6b433362e7ad |
(0033340) Utkarsh Ayachit (administrator) 2014-09-14 11:30 |
Topics merged into master: 10643_chart_legend_properties (VTK) 13139-plot-small-geometry 14931-cluttered-histogram 14983_catalyst_programmablefilter 14990_finalize_catalyst_pipelines add-flexibility-to-catalyst-exporter catalyst_fix_plugins fix_text_source pvweb-docs-further-reorganization pvweb-move-firefox-test-to-port-8080 |
(0034051) Alan Scott (manager) 2015-01-09 19:36 |
I "think" I tested this correctly. No errors. Tested interactive compute node, pvbatch, redsky, 8 cores (1 node). 4.3.0 RC1, Linux. |
2014-09-11 15:41 | Utkarsh Ayachit | New Issue | |
2014-09-11 15:45 | Utkarsh Ayachit | Topic Name | => fix_text_source |
2014-09-11 15:45 | Utkarsh Ayachit | Note Added: 0033325 | |
2014-09-11 15:45 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-09-11 15:45 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-09-11 15:45 | Utkarsh Ayachit | Resolution | open => fixed |
2014-09-11 15:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-09-14 11:30 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-09-14 11:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-09-14 11:30 | Utkarsh Ayachit | Note Added: 0033340 | |
2014-09-24 10:13 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-09 19:36 | Alan Scott | Note Added: 0034051 | |
2015-01-09 19:36 | Alan Scott | Status | customer review => closed |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 357ba281 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master ba5698a6 |
