0014971VTK(No Category)public2014-08-26 23:232015-01-09 13:43
Reporterjpt
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version6.0.0
Target VersionFixed in Version6.2.0
Summary0014971: Heap corruption / buffer overflow in vtkPNGWriter when writing to memory and no file name/prefix specified
DescriptionOn Windows 7 / MSVC 11, I am using vtkPNGWriter to create an in-memory PNG image (for later reading by QImage). I began receiving debug errors regarding heap correction on Line 121 of vtkPNGWriter.cxx whenever I called Write():
121: delete [] this->InternalFileName;
It turned out that since I was not specifying file name information (due to using the in-memory result output), an sprintf call on line 106 was missing a format argument for the prefix and generating a formatted string that was longer than the allocated buffer. I was able to avoid the bad branch (lines 104-107) by providing a file prefix to the vtkPNGWriter object prior to calling write(); this workaround avoids the buffer overflow.
I believe the correct action to fix this issue may be to replace:
-106: sprintf(this->InternalFileName, this->FilePattern,this->FileNumber);
by
+106: sprintf(this->InternalFileName, this->FilePattern,"",this->FileNumber);
so that the format string in FilePattern "%s.%d" has the correct number of applied arguments. Or, to use a safer variant of sprintf.
TagsNo tags attached.
ProjectTBD
Typecrash
 Relationships
  Notes
(0033291)
2014-08-27 13:07
A fix is up for gerrit review:
http://review.source.kitware.com/#/t/4576 [^]
It would be great if you could test the patch out and confirm that it addresses this issue.
Thanks.
(0033531)
2014-10-02 15:47
merged into master.
 Issue History
2014-08-26 23:23 jpt New Issue
2014-08-27 12:52 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2014-08-27 12:52 Utkarsh Ayachit Status backlog => tabled
2014-08-27 13:07 Utkarsh Ayachit Note Added: 0033291
2014-10-02 09:58 Utkarsh Ayachit Status tabled => backlog
2014-10-02 09:58 Utkarsh Ayachit Status backlog => gerrit review
2014-10-02 15:47 Utkarsh Ayachit Note Added: 0033531
2014-10-02 15:47 Utkarsh Ayachit Status gerrit review => closed
2014-10-02 15:47 Utkarsh Ayachit Resolution open => fixed
2014-10-02 15:47 Utkarsh Ayachit Fixed in Version => 6.2.0
2015-01-09 13:43 Utkarsh Ayachit Source_changeset_attached => VTK master fa94f63a
2015-01-09 13:43 Utkarsh Ayachit Source_changeset_attached => VTK master 126135c2
