0014956 | ParaView | (No Category) | public | 2014-08-19 15:03 | 2015-01-11 08:15 | ||||
Summary | 0014956: Extract selection is broken | ||||||||
Description | * Linux, master, local server. * Open can.exo. (I loaded all vars, but not necessary). Apply. * +Y (so you can see the two blocks). * Select block icon. Select the plate. The plate correctly gets selected. * Extract Selection. Apply. <<Bug>> Notice that after you run the Extract Selection filter, the plate gets unselected. This isn't just cosmetic - you then get nothing with an extract selection. Basic functionality. Thus, need to fix for 4.2. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14956_fix_extract_selection | ||||||||
(0033293) Utkarsh Ayachit (administrator) 2014-08-27 13:50 |
commit 9aa80f3f69e0362afab3957addb0829d11c99283 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Aug 27 13:48:37 2014 -0400 BUG 0014956: Stop accidental selection clearing. pqMultiBlockInspectorPanel was accidentally clearing the selection when the active source changed. Fixed that. This was causing BUG 0014956. Change-Id: Ic3fe97b4ea5567e8f078ed443d917840ceb1dfe6 |
(0033295) Utkarsh Ayachit (administrator) 2014-08-28 09:25 |
SUMMARY --------------------------------------------- Topics merged into master: 14956_fix_extract_selection add-vtk-adios fix-catalyst-base (VTK) support-future-use-of-crossbar-io |
(0033299) Alan Scott (manager) 2014-08-28 18:59 |
Tested master, Linux, local server. |
2014-08-19 15:03 | Alan Scott | New Issue | |
2014-08-19 15:03 | Alan Scott | Target Version | => 4.2 |
2014-08-19 15:56 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-08-19 15:56 | Utkarsh Ayachit | Status | backlog => todo |
2014-08-27 13:50 | Utkarsh Ayachit | Topic Name | => 14956_fix_extract_selection |
2014-08-27 13:50 | Utkarsh Ayachit | Note Added: 0033293 | |
2014-08-27 13:50 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-08-27 13:50 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-08-27 13:50 | Utkarsh Ayachit | Resolution | open => fixed |
2014-08-28 09:25 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-08-28 09:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-28 09:25 | Utkarsh Ayachit | Note Added: 0033295 | |
2014-08-28 18:59 | Alan Scott | Note Added: 0033299 | |
2014-08-28 18:59 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d34dbd79 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 9aa80f3f |
