0014953 | ParaView | (No Category) | public | 2014-08-18 18:47 | 2015-09-06 12:18 | ||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0014953: Esc to clear text does not work in Settings dialog | ||||||||
Description | In the settings dialog box, the search bar at the top when empty and not in focus has the instructions "Search ... (use Esc to clear text)" (similar to the search at the top of the properties. These instructions do not actually work with respect to hitting escape. When you hit escape, the dialog box closes. I'm not sure what the right behavior here is, but I think it might be best to disable the behavior of closing the dialog box when you hit escape. | ||||||||
Project | TBD | ||||||||
Topic Name | 14953_fix_Esc_key_in_settings_dialog | ||||||||
(0034106) Utkarsh Ayachit (administrator) 2015-01-23 10:46 |
commit 525d86666261190a6485fd139ee7c4e474e2866d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jan 23 10:38:02 2015 -0500 Fixed BUG 0014953. Properly handle Esc key in Search box. To fix BUG 0014953, we properly handle Esc key in the Search box. pqSearchBox now eats the Esc key if the Esc key will clear the text in the Search box and passes it only if the text box is already empty. Passing it through will cause the parent widget to do its default thing, e.g. closing of dialogs. As a result the Settings dialog now behaves as follows: when there is some text in the Search box, hitting Esc will clear it. If you hit Esc again (or when the Search box) is empty, the dialog does it's default thing, i.e it closes. Change-Id: I4b3c47f8056cf5f0311a9e96bda6a0c91173bb5d |
(0034123) Utkarsh Ayachit (administrator) 2015-01-29 08:06 |
SUMMARY --------------------------------------------- Topics merged into master (v4.3.1-83-gf35be3b): 14953_fix_Esc_key_in_settings_dialog 14957_fix_settings_segfault 15031_fix_multicore_mode 15283_fix_camera_settings_importation 15293-guard-interactive-rendering bag-plot cosmotools-filters-xml fix_mpi_link_issues (VTK) output-window-15240 (VTK) pvweb-loadsave-state-and-save-data pvweb-merge-sources-filters |
(0034246) Alan Scott (manager) 2015-02-18 17:29 |
Tested local server, Linux, master. |
2014-08-18 18:47 | Ken Moreland | New Issue | |
2014-09-09 11:02 | Cory Quammen | Target Version | => 4.2 |
2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.2 => 4.4 |
2015-01-23 10:46 | Utkarsh Ayachit | Topic Name | => 14953_fix_Esc_key_in_settings_dialog |
2015-01-23 10:46 | Utkarsh Ayachit | Note Added: 0034106 | |
2015-01-23 10:46 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2015-01-23 10:46 | Utkarsh Ayachit | Fixed in Version | => git-next |
2015-01-23 10:46 | Utkarsh Ayachit | Resolution | open => fixed |
2015-01-23 10:46 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-01-29 08:06 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2015-01-29 08:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-01-29 08:06 | Utkarsh Ayachit | Note Added: 0034123 | |
2015-02-18 17:29 | Alan Scott | Note Added: 0034246 | |
2015-02-18 17:29 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
