0014940 | ParaView | (No Category) | public | 2014-08-15 12:28 | 2015-09-06 12:18 | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0014940: Plot max over time results in insanity | ||||||||
Description | With the new selection mechanism, plotting the maximum value over time is easy, right? Well, it should be, but when you try it you end up with this crazy plot containing tons of series. To replicate, do the following: 1. Open can.ex2. Load all variables. Apply. 2. Open the Find Data dialog. 3. Create the selection "EQPS" "is max". Run Selection Query. 4. Click Plot Selection Over Time. Apply. Clearly when I did these actions I probably wanted a plot of maximum value of EQPS at every time step. However, what I get is a ton of series giving me different descriptive statistics for every variable. I'm not sure what the right thing to do is, but the current behavior is a mess. | ||||||||
Project | Sandia | ||||||||
Relationships | |||||||||||
(0033228) Ken Moreland (manager) 2014-08-15 16:22 |
After giving this some thought, I think the right thing to do is to chart the data using a method that properly represents the statistics. I've created issue 0014945 that describes a method doing just that. Resolving that bug should also resolve this one. |
(0034414) Utkarsh Ayachit (administrator) 2015-05-14 19:52 |
See: https://gitlab.kitware.com/paraview/paraview/merge_requests/87 [^] |
(0034474) Alan Scott (manager) 2015-06-04 15:55 |
Very nice. Notice I created a separate clean up bug, linked above. Tested master, Linux, local server. (Numpy is failing on my remote build). |
2014-08-15 12:28 | Ken Moreland | New Issue | |
2014-08-15 15:06 | Ken Moreland | Description Updated | |
2014-08-15 16:20 | Ken Moreland | Relationship added | related to 0014945 |
2014-08-15 16:22 | Ken Moreland | Note Added: 0033228 | |
2015-04-09 20:39 | Alan Scott | Project | TBD => Sandia |
2015-04-09 20:39 | Alan Scott | Target Version | => 4.4 |
2015-05-14 19:52 | Utkarsh Ayachit | Note Added: 0034414 | |
2015-05-14 19:52 | Utkarsh Ayachit | Status | backlog => customer review |
2015-05-14 19:52 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-05-14 19:52 | Utkarsh Ayachit | Resolution | open => fixed |
2015-05-14 19:52 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-06-04 15:53 | Alan Scott | Relationship added | related to 0015512 |
2015-06-04 15:55 | Alan Scott | Note Added: 0034474 | |
2015-06-04 15:55 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
