0014931 | ParaView | (No Category) | public | 2014-08-13 18:42 | 2014-09-24 10:13 | ||||
Assigned To | Dan Lipsa | ||||||||
Summary | 0014931: Result of histogram filter doesn't make any sense | ||||||||
Description | When I use the histogram filter, the resulting chart is so cluttered with extraneous data it doesn't make any sense. To replicate, do the following. 1. Load disk_out_ref.ex2. Load all variables. Apply. 2. Add histogram filter. Select Temp as input array. Apply. At this point ParaView creates a new bar chart view as we expect. However, where the previous behavior was to show 10 bars of the bin values for the histogram (which is exactly what a user would expect), a bunch of total and average statistics for each bin of the other scalar fields is also added. None of these other fields should be selected to view by default. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14931-cluttered-histogram | ||||||||
(0033313) Utkarsh Ayachit (administrator) 2014-09-07 14:41 |
The problem is that the default value for "Calculate Averages" advanced property was changed to 1. We should set it to 0 in XML, as before. |
(0033335) Utkarsh Ayachit (administrator) 2014-09-14 11:30 |
Topics merged into master: 10643_chart_legend_properties (VTK) 13139-plot-small-geometry 14931-cluttered-histogram 14983_catalyst_programmablefilter 14990_finalize_catalyst_pipelines add-flexibility-to-catalyst-exporter catalyst_fix_plugins fix_text_source pvweb-docs-further-reorganization pvweb-move-firefox-test-to-port-8080 |
(0033349) Alan Scott (manager) 2014-09-16 16:55 |
Tested master, Linux, remote server. |
2014-08-13 18:42 | Ken Moreland | New Issue | |
2014-09-04 13:49 | Utkarsh Ayachit | Project | TBD => Sandia |
2014-09-04 13:49 | Utkarsh Ayachit | Status | backlog => todo |
2014-09-04 13:49 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-09-07 14:41 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2014-09-07 14:41 | Utkarsh Ayachit | Note Added: 0033313 | |
2014-09-10 13:46 | Dan Lipsa | Status | todo => active development |
2014-09-12 11:02 | Dan Lipsa | Status | active development => gatekeeper review |
2014-09-14 11:28 | Utkarsh Ayachit | Topic Name | => 14931-cluttered-histogram |
2014-09-14 11:30 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-09-14 11:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-09-14 11:30 | Utkarsh Ayachit | Note Added: 0033335 | |
2014-09-16 16:55 | Alan Scott | Note Added: 0033349 | |
2014-09-16 16:55 | Alan Scott | Status | customer review => closed |
2014-09-16 16:55 | Alan Scott | Resolution | open => fixed |
2014-09-24 10:13 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
