0014895 | ParaView | (No Category) | public | 2014-07-29 17:49 | 2016-08-12 09:59 | ||||
Assigned To | T.J. Corona | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0014895: 2d plots log is wrong | ||||||||
Description | On a 2d plot, when a user has positive X axis data that is to be logged, and includes 0 or negative data, ParaView will arbitrarily change this minimum to 1. Please add more intelligence to this algorithm. What I would like is as follows: If (X axis data is all positive) Leave algorithm as is. else (i.e., we have 0 or negative X axis data) Possible-Min = max/(1e-4) If (Possible-Min < 1) Minimum = Possible-Min Else Minimum = 1 A trivial way to reproduce this is as follows: * Master, local server, Linux. * can.exo. All vars on. Apply. * Move forward one time step. * Plot over line. Left Axis Log Scale on. Apply. A huge warning will appear, which makes 2d plots useless. Further, if you click on Use Custom Range, the minimum and maximum are not even preset! This creates huge headaches for users. To show the magnitude of the problem, imagine a user needs to Y axis log scale 4 different 2d plots, with varrying min and max, with a few data points at 0. ParaView becomes very painful to use. | ||||||||
Project | Sandia | ||||||||
Relationships | |||||||||||
(0033137) Alan Scott (manager) 2014-07-29 17:57 |
Adding a relationship between log scaling min and max colors, and Y axis for 2d plots. Algorithm is the same. |
(0033184) Utkarsh Ayachit (administrator) 2014-08-05 14:09 |
In reference to: "Further, if you click on Use Custom Range, the minimum and maximum are not even preset! This creates huge headaches for users." That's already fixed: BUG 0014899 |
(0035721) Alan Scott (manager) 2016-02-11 22:06 |
I'm marking this for must be fixed for 5.1. However, probably needs to be tested to see if it still is a problem. |
(0038610) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-29 17:49 | Alan Scott | New Issue | |
2014-07-29 17:49 | Alan Scott | Target Version | => 4.2 |
2014-07-29 17:54 | Alan Scott | Relationship added | related to 0014896 |
2014-07-29 17:56 | Alan Scott | Relationship added | related to 0014837 |
2014-07-29 17:56 | Alan Scott | Relationship deleted | related to 0014837 |
2014-07-29 17:57 | Alan Scott | Relationship added | related to 0014835 |
2014-07-29 17:57 | Alan Scott | Note Added: 0033137 | |
2014-07-31 13:08 | Utkarsh Ayachit | Status | backlog => todo |
2014-08-05 14:09 | Utkarsh Ayachit | Note Added: 0033184 | |
2014-08-06 15:55 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.2 => 4.4 |
2015-07-08 16:30 | Utkarsh Ayachit | Status | todo => backlog |
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
2016-02-11 22:06 | Alan Scott | Note Added: 0035721 | |
2016-06-21 16:09 | T.J. Corona | Assigned To | Utkarsh Ayachit => T.J. Corona |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038610 | |
