0014859 | ParaView | (No Category) | public | 2014-07-14 03:50 | 2014-08-29 10:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.1 | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014859: It is impossible save the properties of the color legend in the ParaView-4.1 | ||||||||
Description | In the ParaView-3.98.1 was possible save the modification of the Color Legend, in the ParaView-4.1 it is impossible. 1) Run ParaView, import any file. 2) Color a presentation by any data array, display color map 3) Call "Edit color legeng parameters" dialog box 3) Change some parameters (Font size, color, etc... ), push OK button 4) Push "Save as default" button 5) Restart the application 6) Import any file and display color legeng => Parameters of the color legend aren't saved. | ||||||||
Project | ParaViS | ||||||||
(0033018) Utkarsh Ayachit (administrator) 2014-07-15 10:01 |
That's correct. 4.1 and earlier doesn't support that. This is now supported in git/master. You can save the "default" values for the color legend from the "Edit Color Legend" dialog. |
(0033121) Alan Scott (manager) 2014-07-28 20:46 |
Tested master, Linux, remote server. |
2014-07-14 03:50 | Vadim SANDLER | New Issue | |
2014-07-15 10:01 | Utkarsh Ayachit | Note Added: 0033018 | |
2014-07-15 10:02 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-15 10:02 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-07-15 10:02 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-15 10:02 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-07-15 10:02 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Cory Quammen |
2014-07-15 10:02 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-28 20:46 | Alan Scott | Note Added: 0033121 | |
2014-07-28 20:46 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
