0014835ParaView(No Category)public2014-06-30 16:592015-01-11 08:15
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target Version4.3Fixed in Version4.3
Summary0014835: Color legend log minimum color is wrong
DescriptionWhen a user has positive data that is to be logged, and includes 0 or negative data, ParaView will arbitrarily change this the minimum to 1. Please add more intelligence to this algorithm. What I would like is as follows:
If (data is all positive)
  Leave algorithm as is.
else (i.e., we have 0 or negative data)
  Possible-Min = max/(1e-4)
  If (Possible-Min < 1)
    Minimum = Possible-Min
  Else
    Minimum = 1
TagsNo tags attached.
ProjectSandia
Topic Name14835_fix_log_scale_for_coloring
Typeincorrect functionality
 Relationships
related to 0014837closedUtkarsh Ayachit Color legend log ranges - advanced
related to 0014895closedT.J. Corona 2d plots log is wrong
  Notes
(0033802)
2014-11-12 16:46
commit da670c90315add2646db3e940d997a7fb0519fba
Date: Wed Nov 12 16:44:19 2014 -0500
    BUG 0014835: Pick better range for log coloring.
    When switching to using log colors, ParaView now picks a range based on
    the current range, rather than picking an arbitrary range. The logic
    used is:
        Else
           Minimum = 1
    Change-Id: I21eabc08425a2b0fba6129991a1daacd63b9c431
(0033813)
2014-11-15 09:57
Topics merged into master (v4.2.0-133-g7e996c8)
        0015121_fix_ambient_diffuse
(VTK) 15101_fix_particlepath
        15126_fix_properties_panel
        15128_fix_output_window_on_Windows
(VTK) adios-buffer-resizing
        cmake-warnings-20140922
        fix-COPYONLY-usage
        osx-deprecation-warnings
        remove-else-and-endfoo-cmake-args
(VTK) update-vtk-20141114
(0033840)
Alan Scott (manager)
2014-11-24 21:59
Oh, so very very close.
Normal works:
* Linux, master.
* Disk_out_ref.exo, all vars on, apply.
* Color by temp. Change range to [0,913] or [-1,913]. Edit Color Map. Use log scale when mapping data to colors.
* Works correctly.
Fails as follows:
* Linux, master.
* Works correctly.
* Now, without turning log scaling off, change range to [0,913] or [-1,913].
* Works incorrectly (i.e., range is now [1, 913].
(0033841)
2014-11-24 21:59
See failure note above.
(0033863)
2014-11-27 13:03
commit 21b340fbf9ab572ace819ff8637dd8a638e24cff
Date: Thu Nov 27 13:01:41 2014 -0500
    BUG 0014835: Rescale custom range as needed when using log.
    When log scaling is enabled on the color map, if user specifies a custom
    range that is invalid, use the same range scaling logic as when toggling
    to use log-scale as described in the bug report for BUG 0014835.
    Change-Id: Idbfe340d2635f5e2a88e30e88eed62edbdd999be
(0033864)
2014-11-28 08:36
Topics merged into master (v4.2.0-155-gc790012):
(0033869)
2014-12-02 15:47
Perfect.
Tested remote server, master, Linux.
 Issue History
2014-06-30 16:59 Alan Scott New Issue
2014-07-07 16:59 Alan Scott Project TBD => Sandia
2014-07-07 16:59 Alan Scott Target Version => 4.2
2014-07-08 12:55 Alan Scott Relationship added related to 0014837
2014-07-29 17:57 Alan Scott Relationship added related to 0014895
2014-07-31 13:08 Utkarsh Ayachit Status backlog => todo
2014-11-04 12:47 Utkarsh Ayachit Target Version 4.2 => bug_fix
2014-11-12 16:46 Utkarsh Ayachit Topic Name => 14835_fix_log_scale_for_coloring
2014-11-12 16:46 Utkarsh Ayachit Note Added: 0033802
2014-11-12 16:46 Utkarsh Ayachit Status todo => gatekeeper review
2014-11-12 16:46 Utkarsh Ayachit Fixed in Version => git-next
2014-11-12 16:46 Utkarsh Ayachit Resolution open => fixed
2014-11-12 16:46 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2014-11-14 22:56 Utkarsh Ayachit Target Version bug_fix => 4.3
2014-11-15 09:56 Utkarsh Ayachit Fixed in Version git-next => git-master
2014-11-15 09:57 Utkarsh Ayachit Status gatekeeper review => customer review
2014-11-15 09:57 Utkarsh Ayachit Note Added: 0033813
2014-11-24 21:59 Alan Scott Note Added: 0033840
2014-11-24 21:59 Alan Scott Note Added: 0033841
2014-11-24 21:59 Alan Scott Status customer review => todo
2014-11-27 13:03 Utkarsh Ayachit Note Added: 0033863
2014-11-27 13:03 Utkarsh Ayachit Status todo => gatekeeper review
2014-11-27 13:03 Utkarsh Ayachit Fixed in Version git-master => git-next
2014-11-28 08:36 Utkarsh Ayachit Note Added: 0033864
2014-11-28 08:36 Utkarsh Ayachit Status gatekeeper review => customer review
2014-11-28 08:36 Utkarsh Ayachit Fixed in Version git-next => git-master
2014-12-02 15:47 Alan Scott Note Added: 0033869
2014-12-02 15:47 Alan Scott Status customer review => closed
2015-01-02 10:43 Utkarsh Ayachit Fixed in Version git-master => 4.3
2015-01-11 08:13 Utkarsh Ayachit Source_changeset_attached => ParaView master c7900121
2015-01-11 08:13 Utkarsh Ayachit Source_changeset_attached => ParaView master 21b340fb
2015-01-11 08:15 Utkarsh Ayachit Source_changeset_attached => ParaView master 3f57431d
2015-01-11 08:15 Utkarsh Ayachit Source_changeset_attached => ParaView master da670c90
