0014822 | ParaView | (No Category) | public | 2014-06-24 12:06 | 2014-08-29 10:59 | ||||
Reporter | Tristan Coulange | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014822: Customization of tree widget height into xml | ||||||||
Description | Currently the tree widgets/views have the same height. A new feature will allow setting the height into xml files, by adding a hint tag into the corresponding property. So a tree widget/view will have a specific height, depending on the filter/source to which it belongs. | ||||||||
Project | TBD | ||||||||
Topic Name | tree_widget_height | ||||||||
Type | feature | ||||||||
(0032985) Tristan Coulange (developer) 2014-07-08 14:13 |
The change was approved on gerrit : http://review.source.kitware.com/#/t/4336/ [^] ENH: Customization of tree widget height into xml The height of the tree widgets/views can be set into the xml files. It is done by adding a hint tag in the corresponding property. Change-Id: I86b0ed22f4ebb7038e70dd2741d2e02192a758f6 |
(0033009) Utkarsh Ayachit (administrator) 2014-07-11 09:54 |
SUMMARY --------------------------------------------- Topics merged into master: 0014846-update-benchmarks 13575_site_settings_search_paths 14830_initial_opacity_function_display api_cleanup avi-compression dashboard-warnings tree_widget_height volume-rendering-catalyst (VTK) vtkweb-arg-for-custom-ws-endpoint |
2014-06-24 12:06 | Tristan Coulange | New Issue | |
2014-06-24 12:06 | Tristan Coulange | Assigned To | => Tristan Coulange |
2014-06-24 12:07 | Tristan Coulange | Reproducibility | have not tried => always |
2014-06-24 12:07 | Tristan Coulange | Status | backlog => active development |
2014-06-24 12:07 | Tristan Coulange | Fixed in Version | => 4.1 |
2014-07-08 14:13 | Tristan Coulange | Note Added: 0032985 | |
2014-07-08 14:14 | Tristan Coulange | Topic Name | => tree_widget_height |
2014-07-08 14:14 | Tristan Coulange | Status | active development => gatekeeper review |
2014-07-11 09:54 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-master |
2014-07-11 09:54 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2014-07-11 09:54 | Utkarsh Ayachit | Note Added: 0033009 | |
2014-07-16 16:53 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-16 16:53 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-16 16:53 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-21 03:08 | Tristan Coulange | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
