0014800 | ParaView | (No Category) | public | 2014-06-13 10:28 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Summary | 0014800: No consistency for Catalyst generated scripts and state files with regards to floating point number formatting | ||||||||
Description | Bob Kares sent an email with: Why is there no consistency in the output format used for numbers that appear in the Catalyst generated .py script? For example, one of my palettes uses a data range -2e+10 to 2e+10. When I look at what the Catalyst plugin generates by default, the CreatePiecewiseFunction line generated by the Catalyst plugin has -20000000000 and 20000000000. Sometimes "e" format is used instead, but I can’t really discern what the rule is. This same problem occurs in the state files ParaView writes out. This is more than a cosmetic issues because it makes data values you know are there hard to find with a text editor. | ||||||||
Project | LANL-InSitu | ||||||||
Type | usability | ||||||||
(0038581) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-06-13 10:28 | Andy Bauer | New Issue | |
2014-06-13 10:28 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038581 | |
