0014799 | ParaView | (No Category) | public | 2014-06-12 16:59 | 2014-08-29 11:00 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Summary | 0014799: when exporting catalyst scripts, only reader sources should be included in the export dialog | ||||||||
Description | Annotate Time, Text and other sources in the Sources menu shouldn't be included in the export wizard since they can cause problems if they are added to the list of vtkCPDatatDescription inputs. | ||||||||
Project | Catalyst | ||||||||
Topic Name | 14799_optionally_hide_catalyst_inputs | ||||||||
(0032859) Andy Bauer (developer) 2014-06-13 10:32 |
Thinking about this a bit more I think it's worth it to have the option to display the other sources in that menu since for some cases (like using the Wavelet source as the simulation source) it can be helpful. In general though these sources should be hidden unless specifically checked to be shown. |
(0032863) Andy Bauer (developer) 2014-06-16 07:45 |
commit f0c973bc89f0ff50bb3e7b32160b90b902c7957b Author: Andrew Bauer <andy.bauer@kitware.com> Date: Fri Jun 13 19:48:39 2014 -0400 Fixing pv.CoProcessingGUI and pv.CoProcessingGUI-static tests Also added CATALYST to the labels for those tests. Change-Id: Id7404b9b41f9a04ad5c6c6ba0973601a88c678c5 commit 4d13819a4e6b809ab591a9ed68ad907090db147c Author: Andrew Bauer <andy.bauer@kitware.com> Date: Fri Jun 13 13:14:10 2014 -0400 Hiding non-reader sources for CoProcessing plugin in exporter. In general, non-reader sources (e.g. Wavelet) won't have an input association for the simulation but this can be confusing to new users so by default I'm only going to show sources for the export wizard that actually read from a file. There is an option though to turn on all sources to make them available for the situation where the source looks just like the simulation input. Change-Id: I2ccac78c7f0ddd2ab45fcbe5eb0170dc6af4a0ee |
(0032871) Utkarsh Ayachit (administrator) 2014-06-17 07:20 |
Topics merged into master: 14720-RemoveQtWebkit 14737-SearchBoxWidget 14799_optionally_hide_catalyst_inputs 14803_remove_redundant_option bug_color_save_as_default fix_warnings misc_lut_fixes |
(0032899) Alan Scott (manager) 2014-06-18 22:07 |
I think this is a developer tag in git. If I am wrong, tell me how to test and reopen. Until then, closing. |
2014-06-12 16:59 | Andy Bauer | New Issue | |
2014-06-12 16:59 | Andy Bauer | Assigned To | => Andy Bauer |
2014-06-13 10:32 | Andy Bauer | Note Added: 0032859 | |
2014-06-13 12:35 | Andy Bauer | Status | backlog => todo |
2014-06-13 12:35 | Andy Bauer | Status | todo => active development |
2014-06-16 07:45 | Andy Bauer | Topic Name | => 14799_optionally_hide_catalyst_inputs |
2014-06-16 07:45 | Andy Bauer | Note Added: 0032863 | |
2014-06-16 07:45 | Andy Bauer | Status | active development => gatekeeper review |
2014-06-16 07:45 | Andy Bauer | Fixed in Version | => git-next |
2014-06-16 07:45 | Andy Bauer | Resolution | open => fixed |
2014-06-17 07:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-17 07:20 | Utkarsh Ayachit | Note Added: 0032871 | |
2014-06-17 07:28 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-18 22:07 | Alan Scott | Note Added: 0032899 | |
2014-06-18 22:07 | Alan Scott | Status | customer review => closed |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
