0014787ParaView(No Category)public2014-06-07 12:422014-08-29 11:00
ReporterUtkarsh Ayachit
Assigned ToCory Quammen
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target Version4.2Fixed in Version4.2
Summary0014787: Error while loading views/views PythonView
DescriptionMachines with Python enabled (and matplotlib not available), report the following error when one imports paraview.simple.
"Error while loading views/views PythonView"
e.g.
http://open.cdash.org/testDetails.php?test=259911625&build=3362228 [^]
TagsNo tags attached.
ProjectSandia
Topic Name14787_fix_matplotlib_xml
Typeincorrect functionality
 Relationships
related to 0014548closedBen Boeckel (Kitware) Exodus Title string not accessable
  Notes
(0032803)
Cory Quammen (developer)
2014-06-09 12:04
The underlying issue is that the proxy definition for the PythonView is available even when the class vtkSMPythonViewProxy.cxx is not included for compilation. vtkSMPythonViewProxy is conditionally included in the list of source files when PARAVIEW_ENABLE_MATPLOTLIB is enabled.
I think the solution is to separate out the definitions for the PythonView and PythonRepresentation into a separate XML file whose inclusion is conditioned on the value of PARAVIEW_ENABLE_MATPLOTLIB.
(0032804)
2014-06-09 12:23
Note, you can add #ifdef in the xml files. Just make sure that vtkPVConfig has that definition.
At same time, I think PARAVIEW_ENABLE_MATPLOTLIB doesn't support the following use-case:
+ I build and installed ParaView
+ Next installed matplotlib -- ParaView matplotlib views don't start working. I need to rebuild PAraView.
We can punt on this use-case for now, but we should address it at some point.
(0032805)
2014-06-09 13:17
commit df2264d0ab1a755014efb5385a49f014e3f36427
Author: Cory Quammen <cory.quammen@kitware.com>
Date: Mon Jun 9 12:50:03 2014 -0400
    BUG 14787: Fixed error involving Python view
    When ParaView is compiled with the PARAVIEW_ENABLE_MATPLOTLIB option
    OFF, the XML for the Python view and representation are still
    included while the class definitions for the view and representation
    were not built or linked into the executable. This causes
    problems in servermanager.createModule(), which iterates over proxy
    XML definitions and attempts to create proxies defined in the XML.
    Specifically, when servermanager.createModule() tries to create a
    proxy for the python view, it fails because there is no instantiator
    for the Python view.
    Inclusion of the Python view and representation XML definitions
    conditioned on PARAVIEW_ENABLE_MATPLOTLIB fixes this problem.
    Change-Id: I29405016135c14f84c597e2abeab2cec565a548f
(0032816)
2014-06-10 07:38
SUMMARY
Topics merged into master:
        14762_save_color_legend_settings
        cleaning_point_sprite
        fix-transferfunction-applycolormap-text
        static-plugin-loading
(VTK) use-broadcast-rmi-trigger
        use-gatherv-in-collect-information
(0032827)
Alan Scott (manager)
2014-06-10 21:21
Pretty sure I get it. :-)
Tested Linux, master, without compiling in matplotlib. PythonView not available.
 Issue History
2014-06-07 12:42 Utkarsh Ayachit New Issue
2014-06-07 12:42 Utkarsh Ayachit Assigned To => Cory Quammen
2014-06-08 12:10 Utkarsh Ayachit Relationship added related to 0014548
2014-06-08 12:10 Utkarsh Ayachit Priority normal => high
2014-06-08 12:10 Utkarsh Ayachit Target Version => 4.2
2014-06-09 12:04 Cory Quammen Note Added: 0032803
2014-06-09 12:23 Utkarsh Ayachit Note Added: 0032804
2014-06-09 13:17 Cory Quammen Topic Name => 14787_fix_matplotlib_xml
2014-06-09 13:17 Cory Quammen Note Added: 0032805
2014-06-09 13:17 Cory Quammen Status backlog => gatekeeper review
2014-06-09 13:17 Cory Quammen Fixed in Version => git-next
2014-06-09 13:17 Cory Quammen Resolution open => fixed
2014-06-10 07:37 Utkarsh Ayachit Fixed in Version git-next => git-master
2014-06-10 07:38 Utkarsh Ayachit Status gatekeeper review => customer review
2014-06-10 07:38 Utkarsh Ayachit Note Added: 0032816
2014-06-10 21:21 Alan Scott Note Added: 0032827
2014-06-10 21:21 Alan Scott Status customer review => closed
2014-08-29 11:00 Utkarsh Ayachit Fixed in Version git-master => 4.2
