0014779 | VTK | (No Category) | public | 2014-06-05 10:39 | 2015-01-09 13:41 | ||||
Reporter | livia.barazzetti | ||||||||
Product Version | 5.10.1 | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0014779: vtkDistancePolyDataFilter doesn't work with ComputeSecondDistanceOff | ||||||||
Description | When the method ComputeSecondDistanceOff is called, a subsequent call to vtkPolyDataFilter->GetOutput() produces the following error: Algorithm vtkDistancePolyDataFilter(0000000002FDF2E0) returned failure for request: vtkInformation (000000000795B4B0) It seems that vtkDistancePolyDataFilter::GetPolyDataDistance is never called. Here the debug Debug: In e:\dev\vtk5.10.1\filtering\vtkAlgorithm.h, line 158 vtkDistancePolyDataFilter (0000000002FDF2E0): vtkDistancePolyDataFilter (0000000 002FDF2E0): setting AbortExecute to 0 ERROR: In E:\dev\VTK5.10.1\Filtering\vtkExecutive.cxx, line 756 vtkStreamingDemandDrivenPipeline (0000000003686EF0): Algorithm vtkDistancePolyDa taFilter(0000000002FDF2E0) returned failure for request: vtkInformation (0000000 00795B4B0) Debug: Off Modified Time: 26156 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 FROM_OUTPUT_PORT: 0 Debug: In e:\dev\vtk5.10.1\filtering\vtkAlgorithm.h, line 159 vtkDistancePolyDataFilter (0000000002FDF2E0): vtkDistancePolyDataFilter (0000000 002FDF2E0): returning AbortExecute of 0 | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0033005) livia.barazzetti (reporter) 2014-07-11 08:34 |
The problem is in line 68 of vtkDistancePolyDataFilter.cxx : if (!input0 || !input1 || !output0 || !output1) { return 0; } should be changed to if (!input0 || !input1 || !output0 ) //|| !output1 { return 0; } if (this->ComputeSecondDistance && !output1) { return 0; } |
(0033426) Utkarsh Ayachit (administrator) 2014-10-02 09:55 |
This should address the problem: http://review.source.kitware.com/#/t/4752/ [^] |
(0033557) Cory Quammen (developer) 2014-10-02 18:29 |
commit 92be9c22313bd9cbb0814710d446e6db6f9204c8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Oct 2 09:52:01 2014 -0400 BUG 0014779. Fixes for vtkDistancePolyDataFilter. Misc. fixes for vtkDistancePolyDataFilter. Change-Id: I7265dc053e369130e695216ceba37a0fd9d7b27c |
2014-06-05 10:39 | livia.barazzetti | New Issue | |
2014-07-11 08:34 | livia.barazzetti | Note Added: 0033005 | |
2014-10-02 09:32 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-10-02 09:34 | Utkarsh Ayachit | Status | backlog => active development |
2014-10-02 09:49 | Utkarsh Ayachit | Note Added: 0033424 | |
2014-10-02 09:55 | Utkarsh Ayachit | Note Deleted: 0033424 | |
2014-10-02 09:55 | Utkarsh Ayachit | Note Added: 0033426 | |
2014-10-02 09:57 | Utkarsh Ayachit | Status | active development => gerrit review |
2014-10-02 18:29 | Cory Quammen | Note Added: 0033557 | |
2014-10-02 18:29 | Cory Quammen | Status | gerrit review => closed |
2014-10-02 18:29 | Cory Quammen | Resolution | open => fixed |
2014-10-02 18:29 | Cory Quammen | Fixed in Version | => 6.2.0 |
2015-01-09 13:41 | Cory Quammen | Source_changeset_attached | => VTK master ee2c4ff2 |
2015-01-09 13:41 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 92be9c22 |
