0014758 | ParaView | (No Category) | public | 2014-05-28 09:20 | 2014-08-29 11:00 | ||||
Summary | 0014758: developer tag: fix parallel depth buffer for vtkPVRenderViewForAssembly | ||||||||
Description | fix parallel depth buffer for vtkPVRenderViewForAssembly | ||||||||
Project | LANL | ||||||||
Topic Name | fix_assembly_render_view | ||||||||
(0032671) Utkarsh Ayachit (administrator) 2014-05-28 09:21 |
commit cca384bd6c105156954149512c10c2bf7538f399 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed May 14 10:14:41 2014 -0400 Quick-n-dirty pass at fixing the depth buffer in parallel. Here's a first pass at fixing the depth buffer in parallel for vtkPVRenderViewForAssembly. To further clean this up, we should do the following: + Cleanup API on vtkPVSynchronizedRenderer to provide access to depth buffer and color buffer + Teach vtkPVSynchronizedRenderer to user color and depth buffer from IceT when available and grab from frame-buffer when not. + vtkPVRenderViewForAssembly should then use that API to get the color and depth buffer (never having to do actual grabs). This commit exposes internal methods to use for vtkPVRenderViewForAssembly as a quick hack. We can come back and fix the API in future. Change-Id: I4c62e94377750202a43ac6682feb2d72bf17da58 |
(0032695) Utkarsh Ayachit (administrator) 2014-05-30 08:14 |
SUMMARY --------------------------------------------- Topics merged into master: 14679_color_legend_bugs 14734-GoodDefaultSizeForpqProxyWidgetDialog cleanup-cmake fix_assembly_render_view fix_fragment_large_scale fix_plugin_loading_order fix_qt_modules remove-unused-directory --------------------------------------------- Topics reverted from next: 14673_fix_follow_data |
(0032703) Alan Scott (manager) 2014-05-30 22:12 |
Developer tag in git. Closing. |
2014-05-28 09:20 | Utkarsh Ayachit | New Issue | |
2014-05-28 09:21 | Utkarsh Ayachit | Topic Name | => fix_assembly_render_view |
2014-05-28 09:21 | Utkarsh Ayachit | Note Added: 0032671 | |
2014-05-28 09:21 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-05-28 09:21 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-05-28 09:21 | Utkarsh Ayachit | Resolution | open => fixed |
2014-05-28 09:21 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032695 | |
2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-05-30 22:12 | Alan Scott | Note Added: 0032703 | |
2014-05-30 22:12 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
