0014746 | ParaView | (No Category) | public | 2014-05-20 14:25 | 2015-01-09 14:21 | ||||
Reporter | Jeff Mauldin | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 4.1 | ||||||||
Summary | 0014746: catalyst rendering/python rendering editions fail with unstructured grid due to volume mappers | ||||||||
Description | When we build a catalyst edition with everything available (including redering-base and rendering python), we cannot use it with unstructured grids. The problem appears to be tied up with the fact that when you try to create a representation of an unstructured grid, the system tries to create volume mapping/rendering stuff, which is not included in the edition. When I have tried to remove the dependency, either by playing with rendering.xml or skipping the creation of those vtk objects in the .cxx code, I end up with a crash. The test available as .../ParaView/Catalyst/Editions/Rendering-Base/Testing/Rendering-Base/use-rendering-base.py succeeds, but it is a poly data set, not an unstructured grid. To see the error, add a Clip() filter (which has an unstructured grid as output): from paraview.simple import * Sphere() Clip() Show() Render() WriteImage('rendering-base.png') in the above python code, we have added Clip() after Sphere() so that the active source will be an unstructured grid. The Show() will fail, complaining of the absence of some volume mapping stuff. As I mentioned before, when I hack the .cxx code to just not create the vtkObject if it isn't there, I get a crash later. (This test will show the failure in the most recent master version of the repo which I downloaded). | ||||||||
Project | Sandia-Catalyst | ||||||||
Topic Name | volume-rendering-catalyst | ||||||||
Type | crash | ||||||||
(0032698) Andy Bauer (developer) 2014-05-30 16:13 |
I took a shot at fixing this and noticed that I can't currently build the Catalyst rendering edition. Maybe it's just the way I set it up though. I did: 1) python catalyze.py -i Editions/Base -i Editions/Essentials/ -i Editions/Extras/ -i Editions/Enable-Python/ -i Editions/Rendering-Base -i Editions/Rendering-Base-Python/ -o /media/ssddrive/BUILDS/ParaView/CATALYSTEDITIONS/all_with_rendering 2) ../all_with_rendering/cmake.sh ../all_with_rendering/ 3) make I got the following build error: /media/ssddrive/BUILDS/ParaView/CATALYSTEDITIONS/all_with_rendering/ParaViewCore/VTKExtensions/Rendering/vtkPVLODVolume.cxx:26:45: fatal error: vtkUnstructuredGridVolumeMapper.h: No such file or directory |
(0033007) Utkarsh Ayachit (administrator) 2014-07-11 09:53 |
------------------------------------------------------------------------------ | * 89fc12f (stage/volume-rendering-catalyst) catalyst: remove volume rendering | * d95b315 catalyze: remove unpackaged subproxies and representations | * 479afca catalyst: update for new dependencies | * 5212807 catalyst: fix Rendering-Base edition for GL backend changes ------------------------------------------------------------------------------ |
(0033008) Utkarsh Ayachit (administrator) 2014-07-11 09:54 |
SUMMARY --------------------------------------------- Topics merged into master: 0014846-update-benchmarks 13575_site_settings_search_paths 14830_initial_opacity_function_display api_cleanup avi-compression dashboard-warnings tree_widget_height volume-rendering-catalyst (VTK) vtkweb-arg-for-custom-ws-endpoint |
(0034043) Alan Scott (manager) 2015-01-09 14:21 |
Old bug, assuming fixed. Jeff - if you still see this crash, please reopen the bug. Closing. |
2014-05-20 14:25 | Jeff Mauldin | New Issue | |
2014-05-30 15:52 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2014-05-30 16:13 | Andy Bauer | Note Added: 0032698 | |
2014-06-28 10:47 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-07-10 13:47 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Ben Boeckel (Kitware) |
2014-07-11 09:53 | Utkarsh Ayachit | Topic Name | => volume-rendering-catalyst |
2014-07-11 09:53 | Utkarsh Ayachit | Note Added: 0033007 | |
2014-07-11 09:53 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-11 09:53 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-07-11 09:53 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-11 09:54 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-07-11 09:54 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2014-07-11 09:54 | Utkarsh Ayachit | Note Added: 0033008 | |
2014-07-16 16:54 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-16 16:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-09 14:21 | Alan Scott | Note Added: 0034043 | |
2015-01-09 14:21 | Alan Scott | Status | customer review => closed |
