0014744ParaView(No Category)public2014-05-20 08:402014-08-29 11:00
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version4.2Fixed in Version4.2
Summary0014744: Developer tag: Cleanup view plugin infrastructure
DescriptionThe mechanism to add new views in unnecessary complicated. There should not be any need to add pqView classes anymore. We need to simplify the infrastructure.
TagsNo tags attached.
ProjectKitware
Topic Name14744_cleanup_views
Typeincorrect functionality
 Relationships
  Notes
(0032654)
2014-05-20 08:41
commit 7091737a5c9ae0dbb9f298bba2d761147b75ba95
Date: Sat May 17 16:14:03 2014 -0400
    Refactoring how view types are created and registered with ParaView.
    This commits simplifies how views are added to ParaView. In past, we
    need to create a pqView subclass and then add that using
    pqViewModuleInterface implementation. After this change, one can add new
    view types by simply defining new proxy types under the "views" group.
    If you need to add a pqView subclass, or specify a pqView subclass to
    use with your new view type, simply use add_pqproxy() macro, instead of
    add_paraview_view_module() macro. Label used for the view is now
    garnered from the proxy itself (vtkSMProxy::GetXMLLabel()).
    Updating plugins, examples to use this new code.
    Removed pqStandardViewModules since it's no longer relevant. If you're
    using that class, simply remove it from your code and ParaView will
    continue to work as expected.
    Moved view XML definitions that were "internal" to "internal_views"
    group. This keeps the list of "available" views clean. Plugins may have
    to be updated if they are using "ViewBase" proxy definition.
    Change-Id: I15b329ea13ce526ca3c1fe016da0201ac5826355
(0032665)
2014-05-28 07:00
SUMMARY
Topics merged into master:
        14723_export_coprocessing_scripts
        14742_vtkImageDataToUniformGrid
        14744_cleanup_views
        14748_compile_cth_markers_in_by_default
        14753_PluginSettings
        cleanup_viewframe_interface
        dashboard_maintenance
        fix-install-test
        fix_intel_compiler_mpich_issues
        fix_settings_server_processes
        pvweb-ubuntu-14LTS-doc-update
        settings_custom_apps
        use-external-data
(0032709)
Alan Scott (manager)
2014-05-30 22:32
Developer tag in git. Closing.
 Issue History
2014-05-20 08:40 Utkarsh Ayachit New Issue
2014-05-20 08:41 Utkarsh Ayachit Topic Name => 14744_cleanup_views
2014-05-20 08:41 Utkarsh Ayachit Note Added: 0032654
2014-05-20 08:41 Utkarsh Ayachit Status backlog => gatekeeper review
2014-05-20 08:41 Utkarsh Ayachit Fixed in Version => git-next
2014-05-20 08:41 Utkarsh Ayachit Resolution open => fixed
2014-05-20 08:41 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2014-05-28 06:59 Utkarsh Ayachit Fixed in Version git-next => git-master
2014-05-28 07:00 Utkarsh Ayachit Status gatekeeper review => customer review
2014-05-28 07:00 Utkarsh Ayachit Note Added: 0032665
2014-05-30 22:32 Alan Scott Note Added: 0032709
2014-05-30 22:32 Alan Scott Status customer review => closed
2014-06-17 09:22 Utkarsh Ayachit Target Version => 4.2
2014-08-29 11:00 Utkarsh Ayachit Fixed in Version git-master => 4.2
