0014738 | ParaView | (No Category) | public | 2014-05-19 08:08 | 2014-08-29 11:00 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014738: Crash in the vtkPVGeometryFilter on the simple case | ||||||||
Description | An attached file "carre.vtu" contains 4 quadrangles. Applying of the vtkPVGeometryFilter to this data set leads to the crash of the application. Run attached python script carre.py, in the result application crashes, in the console displayed the following log: paraview version 4.1.0 ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 389 vtkPVSessionCore (0x2b35510): Object type: vtkPVGeometryFilter, could not find requested method: "SetMakeOutlineOfInput" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkPVGeometryFilter (0x61711c0)} Argument 1 = string_value {SetMakeOutlineOfInput} Argument 2 = int32_value {0} ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0x2b35510): Aborting execution for debugging purposes. ############ ABORT ############# ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 486 vtkSISourceProxy (0x6170ff0): Could not parse property: MakeOutlineOfInput ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ClientServerCore/Core/vtkPVAlgorithmPortsInformation.cxx, line 56 vtkPVAlgorithmPortsInformation (0x613c650): Could not downcast vtkAlgorithm. ERROR: In /dn47/SALOME/PRODUCTS/7x/opt/CentOS.6.3.64/7.4.0/tmp/ParaView-4.1.0_SRC/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 267 vtkSISourceProxy (0x6170ff0): Incorrect message received. Missing xml_group and xml_name information. global_id: 4840 location: 1 [paraview_protobuf.ProxyState.property] { name: "Input" value { type: INPUT proxy_global_id: 4829 port_number: 0 } } Invalid output port : pqPipelineSource::getOutputPort( 0 ). Available number of output ports: 0. | ||||||||
Project | ParaViS | ||||||||
Topic Name | FixGeometryFilterProxy | ||||||||
Attached Files | carre.zip [^] (964 bytes) 2014-05-19 08:12 | ||||||||
(0032750) Joachim Pouderoux (developer) 2014-06-05 11:03 |
The crash is due to a proxy property (MakeOutlineOfInput) that has been removed from the c++ class in September 2012 (http://www.paraview.org/gitweb?p=ParaView.git;a=commit;h=150d8db57821799ef62d9ca236135c98664fe0f8 [^]). In the ParaViewCore/ServerManager/SMApplication/Resource/filters.xml just remove the follwing tag from the GeometryFilter proxy: <IntVectorProperty animateable="0" command="SetMakeOutlineOfInput" default_values="0" name="MakeOutlineOfInput" number_of_elements="1"> <BooleanDomain name="bool" /> <Documentation>Causes filter to try to make geometry of input to the algorithm on its input.</Documentation> </IntVectorProperty> We will push a fix soon. |
(0032751) Joachim Pouderoux (developer) 2014-06-05 11:08 |
Change I455d8a2e: Remove a missing property from the GeometryFilter proxy. The bug is described in ticket 0014738. Creating a GeometryFilter proxy from Python generates a crash because the SetMakeOutlineOfInput properties does not exist anymore - removed in Sept 2012. Change-Id: I455d8a2e0c4eddb6743f49a841281ad81fbb86c7 |
(0032767) Utkarsh Ayachit (administrator) 2014-06-06 05:08 |
SUMMARY --------------------------------------------- Topics merged into master: 14573-deprecate-legacy-panels 14772_CTH_Tracers_on_by_default AddSideBySideHorizStereoModeToSaveDialogs FixGeometryFilterProxy FixPluginPathSeparatorIssue data-download-without-testing discretize_color manual-ParaViewData-option (VTK) refactor-piece-and-extent (VTK) refactor-piece-and-extent-2 static-plugins |
(0032838) Alan Scott (manager) 2014-06-10 21:58 |
Assuming fixed, and closing untested. If this crash still exists, feel free to reopen. |
2014-05-19 08:08 | Vadim SANDLER | New Issue | |
2014-05-19 08:12 | Vadim SANDLER | File Added: carre.zip | |
2014-06-05 10:59 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-06-05 10:59 | Joachim Pouderoux | Reproducibility | have not tried => always |
2014-06-05 11:03 | Joachim Pouderoux | Note Added: 0032750 | |
2014-06-05 11:08 | Joachim Pouderoux | Note Added: 0032751 | |
2014-06-05 11:09 | Joachim Pouderoux | Status | backlog => active development |
2014-06-05 11:54 | Joachim Pouderoux | Status | active development => gatekeeper review |
2014-06-05 11:54 | Joachim Pouderoux | Resolution | open => fixed |
2014-06-06 05:00 | Utkarsh Ayachit | Topic Name | => FixGeometryFilterProxy |
2014-06-06 05:07 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-06-06 05:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-06 05:08 | Utkarsh Ayachit | Note Added: 0032767 | |
2014-06-10 21:58 | Alan Scott | Note Added: 0032838 | |
2014-06-10 21:58 | Alan Scott | Status | customer review => closed |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
