0014573 | ParaView | (No Category) | public | 2014-02-13 15:22 | 2014-08-29 11:00 | ||||
Assigned To | Sankhesh Jhaveri | ||||||||
Summary | 0014573: Deprecate pqSpreadSheetDisplayEditor and pqTextDisplayPropertiesWidget | ||||||||
Description | pqSpreadSheetDisplayEditor and pqTextDisplayPropertiesWidget are old style display panels. We need to upgrade both of them to use the new Properties panel infrastructure. Basically getting rid of pqStandardLegacyDisplayPanels class an all iclasses it creates/uses. ParaView should not use legacy display panels anymore. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14573-deprecate-legacy-panels | ||||||||
Type | feature | ||||||||
(0032499) Utkarsh Ayachit (administrator) 2014-03-20 16:50 |
For these, start by removing those classes from pqStandardLegacyDisplayPanels. Now create those representations as appropriate and try to fix the "Display" part of the properties panel to match the old one. YOu'll need to create custom property widgets or hide irrelevant properties from those representations as needed. |
(0032500) Utkarsh Ayachit (administrator) 2014-03-20 16:51 |
This is a good reference to understanding how the "new" properties panel works: http://paraview.org/Wiki/ParaView/Properties_Panel [^] |
(0032758) Utkarsh Ayachit (administrator) 2014-06-06 04:59 |
------------------------------------------------------------------------------ | * 70090ec (stage/14573-deprecate-legacy-panels) FIX: Fixed test using the new TextLocationWidget | * 4fbf55a Changes in FontPropertyWidget and TextLocationWidget | * f6ce4c8 Removed legacy display panel widgets | * bde3874 Use new display panel for spreadsheet view | * ef023d4 Renamed pqTextWindowLocationWidget to pqTextLocationWidget | * e0403c3 Reworked Text Source display panel | * 2b1e24f Deprecate legacy display panel for the Text Source ------------------------------------------------------------------------------ |
(0032761) Utkarsh Ayachit (administrator) 2014-06-06 05:08 |
SUMMARY --------------------------------------------- Topics merged into master: 14573-deprecate-legacy-panels 14772_CTH_Tracers_on_by_default AddSideBySideHorizStereoModeToSaveDialogs FixGeometryFilterProxy FixPluginPathSeparatorIssue data-download-without-testing discretize_color manual-ParaViewData-option (VTK) refactor-piece-and-extent (VTK) refactor-piece-and-extent-2 static-plugins |
(0032839) Alan Scott (manager) 2014-06-10 21:59 |
Developer tag in git. Closing. |
2014-02-13 15:22 | Utkarsh Ayachit | New Issue | |
2014-02-13 15:22 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2014-02-13 15:22 | Utkarsh Ayachit | Status | backlog => todo |
2014-03-20 16:50 | Utkarsh Ayachit | Note Added: 0032499 | |
2014-03-20 16:51 | Utkarsh Ayachit | Note Added: 0032500 | |
2014-06-06 04:59 | Utkarsh Ayachit | Topic Name | => 14573-deprecate-legacy-panels |
2014-06-06 04:59 | Utkarsh Ayachit | Note Added: 0032758 | |
2014-06-06 04:59 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-06-06 04:59 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-06-06 04:59 | Utkarsh Ayachit | Resolution | open => fixed |
2014-06-06 05:07 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-06 05:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-06 05:08 | Utkarsh Ayachit | Note Added: 0032761 | |
2014-06-10 21:59 | Alan Scott | Note Added: 0032839 | |
2014-06-10 21:59 | Alan Scott | Status | customer review => closed |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
