0014566 | ParaView | (No Category) | public | 2014-02-11 13:58 | 2015-01-02 10:43 | ||||
Reporter | Jeff Mauldin | ||||||||
Assigned To | Andy Bauer | ||||||||
Product Version | 4.1 | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0014566: in catalyst, supplying using a script named "test.py" appears to fail for some reason | ||||||||
Description | For some reason, using a script named "test.py" with catalyst does not work. The error can be seen in the CxxFullExample from the catalyst example code. Build and run the example. It works fine if you run using the supplied example script, feslicescript.py, for example with the run line ./FEDriver feslicescript.py (with the .py file copied into the run directory) it works fine. However, copy feslicescript.py to the name test.py and then run ./FEDriver test.py It does not work and you get error AttributeError: 'module' object has no attribute 'RequestDataDescription' Traceback (most recent call last): File "<string>", line 2, in <module> AttributeError: 'module' object has no attribute 'RequestDataDescription' Traceback (most recent call last): File "<string>", line 2, in <module> AttributeError: 'module' object has no attribute 'DoCoProcessing' | ||||||||
Project | Sandia-Catalyst | ||||||||
(0033784) Utkarsh Ayachit (administrator) 2014-11-07 14:53 |
Seems to work for me. Asking Andy to test it out once again with >4.2 |
(0033785) Andy Bauer (developer) 2014-11-07 15:08 |
I used the following script to test: =========== from paraview.simple import * from paraview import coprocessing print 'here' def RequestDataDescription(datadescription): print "Callback to populate the request for current timestep" # ------------------------ Processing method ------------------------ def DoCoProcessing(datadescription): print "Callback to do co-processing for current timestep" =========== It worked for master (11/7/2014) and PV 4.2 but failed for PV 4.1 so it looks like it got fixed. I'm going to close this issue as fixed since it was reported for not working in 4.1. |
(0033786) Andy Bauer (developer) 2014-11-07 15:10 |
Dang it. I don't have the ability to change the status to customer review. |
(0033934) Alan Scott (manager) 2014-12-10 16:22 |
Closing untested. I will have Jeff try again in the next month, and we will reopen if it is still a problem. |
2014-02-11 13:58 | Jeff Mauldin | New Issue | |
2014-11-07 14:05 | Utkarsh Ayachit | Target Version | => bug_fix |
2014-11-07 14:53 | Utkarsh Ayachit | Assigned To | => Andy Bauer |
2014-11-07 14:53 | Utkarsh Ayachit | Note Added: 0033784 | |
2014-11-07 15:08 | Andy Bauer | Note Added: 0033785 | |
2014-11-07 15:09 | Andy Bauer | Resolution | open => fixed |
2014-11-07 15:09 | Andy Bauer | Status | backlog => todo |
2014-11-07 15:09 | Andy Bauer | Status | todo => active development |
2014-11-07 15:09 | Andy Bauer | Status | active development => gatekeeper review |
2014-11-07 15:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-11-07 15:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-07 15:09 | Andy Bauer | Status | customer review => backlog |
2014-11-07 15:09 | Andy Bauer | Resolution | fixed => reopened |
2014-11-07 15:10 | Andy Bauer | Note Added: 0033786 | |
2014-11-08 11:16 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-08 11:16 | Utkarsh Ayachit | Resolution | reopened => fixed |
2014-11-08 11:16 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2014-12-10 16:22 | Alan Scott | Note Added: 0033934 | |
2014-12-10 16:22 | Alan Scott | Status | customer review => closed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
