0014557 | ParaView | (No Category) | public | 2014-02-04 20:45 | 2015-01-11 08:17 | ||||
Summary | 0014557: Color legend doesn't update properly | ||||||||
Description | Marking high, since this can misrepresent data. Must be fixed for 4.2. Linux, master, local server. Open can.exo. All vars on. Apply. Color by EQPS. Color legend on. Show Color Editor. Rescale to data range over all timesteps. Do exactly as follows: Click Yes. Don't move the mouse. Min and Max on EQPS has not changed. Slowly move the mouse right, over the color legend. Color legend will update. This doesn't need clicking the Update icon. Either it should automatically update, or it should require clicking the Update icon. If I had my preference, both Rescale to Data Range (on the toolbars and in the Color Map Editor) and Rescale to Data Range over All Timesteps would automatically apply. This is a bug. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14557-color-legend-update | ||||||||
(0032314) Utkarsh Ayachit (administrator) 2014-02-13 14:11 |
I agree. Both Rescale to Data Range (on the toolbars and in the Color Map Editor) and Rescale to Data Range over All Timesteps should automatically apply the changes. |
(0032347) Sankhesh Jhaveri (developer) 2014-02-18 19:46 |
Could not reproduce as of git-master@a001976f5 |
(0032369) Utkarsh Ayachit (administrator) 2014-02-21 15:15 |
reopening since I can reproduce this (as can Alan). |
(0032405) Sankhesh Jhaveri (developer) 2014-02-25 15:13 |
commit 2aa1a16be66c3302e81cc0f1117305d451bd83e8 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Tue Feb 25 14:58:55 2014 -0500 BUG: Render after rescaling color range This change fixes issue 14557(http://www.paraview.org/Bug/view.php?id=14557 [^]) Change-Id: I0e4250840fee481153fad7cdd81be2d98e716121 |
(0032421) Utkarsh Ayachit (administrator) 2014-02-27 11:29 |
Topics merged into master: 14557-color-legend-update (VTK) 14581-volume-render-bug 14584-frequency-live-view 14600-restore-numpy 14602_fix_text_representation fix_mili |
(0032517) Alan Scott (manager) 2014-03-20 22:03 |
Nope, still wrong (although it is better). I missed one step. Note that the issue could be remote server, but i doubt it. Linux, remote server, master. Do exactly as follows: * Open can.exo. All vars on. Apply. * Forward one time step. * Color by EQPS. * Toggle Color Legend Visibility. * Color Editor. * Rescale to Data Range. * On the Color editor, click on the second icon down from the top - the Rescale to Custom Range. Edit as Min -1 and Max 10. Rescale - AND DON'T MOVE YOUR MOUSE. Now, slowly, move the mouse to the right, across the center of the Color Legend. <<Bug - the color legend will magically update>> Ask Utkarsh - I am tempted to say that Rescale to Custom Range should also be automatically applied, as are Rescale to Data Range and Rescale to Data Range across all timesteps. |
(0032520) Sankhesh Jhaveri (developer) 2014-03-21 10:11 |
commit 8202aa4a10073f49c4e08e70aeb00362c58e1946 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Fri Mar 21 10:05:47 2014 -0400 Render view automatically on rescale to custom range This change fixes issue 14557 Change-Id: I625ceb578c087d80b9e9a4e037693a575a7d6b6d Qt/ApplicationComponents/pqColorOpacityEditorWidget.cxx | 3 +++ 1 file changed, 3 insertions(+) |
(0032537) Utkarsh Ayachit (administrator) 2014-03-28 11:55 |
--------------------------------------------- Topics merged into master: 14557-color-legend-update 14580-top-level-checkbox (VTK) 14615-fix-mpi-segfault 14650_check_bounds catalyst-web delaunay3d-alpha-bools fix_qt5_dashboard_failures pvweb-doc-update (VTK) vtk_02_20_2014 14632-find-data-query-combobo |
(0032557) Alan Scott (manager) 2014-04-08 19:44 |
Nope, still wrong. Please try all the combinations you can think of before moving to customer review. Here is the latest. Linux, remote server, master. Do exactly as follows: * Open can.exo. All vars on. Apply. * Forward one time step. * Color by EQPS. * Toggle Color Legend Visibility. * Color Editor. * Use log scale when mapping data to colors. * Now, slowly move the mouse to the left, touching the color legend. It will redraw, taking into account the log. It should only redraw when you click update!! |
(0032884) Utkarsh Ayachit (administrator) 2014-06-17 09:32 |
Alan, Unlike the "Properties" panel, the "Update" is not equivalent to "Apply". In other words, changes to this panel are "pushed" immediately. Hence the missing "Reset", since the changes have already been applied. "Update" simply triggers a render. Maybe this button should be renamed as "Render Views" or something like that, rather than calling it "Update"? |
(0032890) Alan Scott (manager) 2014-06-17 21:26 |
OK, I will agree - this is strange behavior, but correct behavior. The reason to not just always re-render is volume rendering. If a user is inserting a lot of points in the volume rendering control, you don't want ParaView frozen for each change. What do you think about changing the default to "auto apply"? If a user wants that off, they can change it... |
(0032951) Utkarsh Ayachit (administrator) 2014-06-27 15:47 |
commit 2159eb3f00d76b9018dc3066d5f0100350e78836 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jun 27 15:45:20 2014 -0400 BUG 0014557: Fixed updating on Color Map editor. + Renamed button as "Render Views" instead of "Update" to make it clearer what the button does. + Changed default to auto-update/auto-render all the view when LUT is changed. + Also added icon for Save as default to make the UI consistent with Properties panel. Change-Id: Ia69c6087de5c912cce8e21c422e309aa8bf1d031 |
(0032955) Utkarsh Ayachit (administrator) 2014-06-30 08:24 |
SUMMARY --------------------------------------------- Topics merged into master: 14557-color-legend-update (VTK) 14713_fix_lsdyna_reader 14788-pqTextEdit 14814_fix_cell_point_label_format 14827_fix_paraview_module_requirements misc_quad_view_fixes |
(0032982) Alan Scott (manager) 2014-07-07 22:04 |
Waiting on an answer from Utkarsh, if we need a "restore state" button in the Color Map Editor. Otherwise, ready to close. |
(0033123) Alan Scott (manager) 2014-07-28 20:49 |
I wrote up "restore color map editor state" as bug 14845. Marking this one closed. Tested Linux, master, remote server. Nice! |
2014-02-04 20:45 | Alan Scott | New Issue | |
2014-02-13 14:00 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2014-02-13 14:00 | Utkarsh Ayachit | Status | backlog => todo |
2014-02-13 14:11 | Utkarsh Ayachit | Note Added: 0032314 | |
2014-02-18 19:46 | Sankhesh Jhaveri | Note Added: 0032347 | |
2014-02-18 19:46 | Sankhesh Jhaveri | Status | todo => closed |
2014-02-18 19:46 | Sankhesh Jhaveri | Resolution | open => fixed |
2014-02-18 19:46 | Sankhesh Jhaveri | Fixed in Version | => git-master |
2014-02-18 20:40 | Utkarsh Ayachit | Status | closed => customer review |
2014-02-21 15:15 | Utkarsh Ayachit | Note Added: 0032369 | |
2014-02-21 15:15 | Utkarsh Ayachit | Status | customer review => todo |
2014-02-25 15:13 | Sankhesh Jhaveri | Topic Name | => 14557-color-legend-update |
2014-02-25 15:13 | Sankhesh Jhaveri | Note Added: 0032405 | |
2014-02-25 15:13 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-02-27 11:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-27 11:29 | Utkarsh Ayachit | Note Added: 0032421 | |
2014-03-20 22:03 | Alan Scott | Note Added: 0032517 | |
2014-03-20 22:03 | Alan Scott | Status | customer review => todo |
2014-03-21 10:11 | Sankhesh Jhaveri | Note Added: 0032520 | |
2014-03-21 10:11 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-03-28 11:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-28 11:55 | Utkarsh Ayachit | Note Added: 0032537 | |
2014-04-08 19:44 | Alan Scott | Note Added: 0032557 | |
2014-04-08 19:44 | Alan Scott | Status | customer review => todo |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-17 09:32 | Utkarsh Ayachit | Note Added: 0032884 | |
2014-06-17 09:32 | Utkarsh Ayachit | Assigned To | Sankhesh Jhaveri => Utkarsh Ayachit |
2014-06-17 21:26 | Alan Scott | Note Added: 0032890 | |
2014-06-27 15:47 | Utkarsh Ayachit | Note Added: 0032951 | |
2014-06-27 15:47 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-06-30 08:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-30 08:24 | Utkarsh Ayachit | Note Added: 0032955 | |
2014-07-07 22:04 | Alan Scott | Note Added: 0032982 | |
2014-07-28 20:49 | Alan Scott | Note Added: 0033123 | |
2014-07-28 20:49 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:17 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4f41e2d5 |
2015-01-11 08:17 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 2159eb3f |
