0014552 | VTK | (No Category) | public | 2014-01-31 09:28 | 2014-10-06 08:56 | ||||
Reporter | Paul Melis | ||||||||
Assigned To | David Gobbi | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0014552: VTK 6.1.0 configure doesn't check version of Python interpreter | ||||||||
Description | On my (Arch Linux) machine 'python' defaults to Python 3.3. There's also 'python2' and 'python3' symlinks for the interpreters of the different versions: [paulm@saralt0169:~]$ ls -l /usr/bin/python* lrwxrwxrwx 1 root root 7 Sep 6 09:31 /usr/bin/python -> python3 lrwxrwxrwx 1 root root 9 Sep 6 09:56 /usr/bin/python2 -> python2.7 -rwxr-xr-x 1 root root 6240 Sep 6 09:56 /usr/bin/python2.7 -rwxr-xr-x 1 root root 1668 Sep 6 09:56 /usr/bin/python2.7-config lrwxrwxrwx 1 root root 16 Sep 6 09:56 /usr/bin/python2-config -> python2.7-config -rwxr-xr-x 1 root root 94 Aug 22 14:15 /usr/bin/python2-pyuic4 lrwxrwxrwx 1 root root 9 Sep 6 09:31 /usr/bin/python3 -> python3.3 -rwxr-xr-x 2 root root 10400 Sep 6 09:31 /usr/bin/python3.3 lrwxrwxrwx 1 root root 17 Sep 6 09:31 /usr/bin/python3.3-config -> python3.3m-config -rwxr-xr-x 2 root root 10400 Sep 6 09:31 /usr/bin/python3.3m -rwxr-xr-x 1 root root 1972 Sep 6 09:31 /usr/bin/python3.3m-config lrwxrwxrwx 1 root root 16 Sep 6 09:31 /usr/bin/python3-config -> python3.3-config lrwxrwxrwx 1 root root 14 Sep 6 09:31 /usr/bin/python-config -> python3-config I'm configuring VTK 6.1.0 with the following options: [paulm@saralt0169:~/c/vtk-6.1.0-release]$ cmake ../VTK-6.1.0/ \ -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_INSTALL_PREFIX=/home/paulm/software/vtk-6.1.0 \ -DVTK_Group_Web=ON -DVTK_Group_Qt=ON -DVTK_WRAP_PYTHON=ON ... -- Check size of int - done -- Check size of long -- Check size of long - done -- Check size of long long -- Check size of long long - done -- Configuring done -- Generating done -- Build files have been written to: /home/paulm/c/vtk-6.1.0-release The used python configuration values are inconsistent, as the version of the python executable (3.3) is not checked against the version of the library found (2.7): [paulm@saralt0169:~/c/vtk-6.1.0-release]$ grep python CMakeCache.txt PYTHON_EXECUTABLE:FILEPATH=/usr/bin/python //Extra libraries to link when linking to python (such as "z" for PYTHON_INCLUDE_DIR:PATH=/usr/include/python2.7 PYTHON_LIBRARY:FILEPATH=/usr/lib64/libpython2.7.so //Utility library needed for vtkpython //Directory where python modules will be built //Directory where python modules will be installed VTK_INSTALL_PYTHON_MODULE_DIR:PATH=lib/python2.7/site-packages vtkWebCore_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtksys;general;vtkFiltersGeneral;general;/usr/lib64/libpython2.7.so;general;vtkIOCore;general;vtkIOImage;general;vtkRenderingCore;general;vtkParallelCore;general;vtkWebGLExporter; vtkWrappingPythonCore_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;/usr/lib64/libpython2.7.so;general;vtksys; FIND_PACKAGE_MESSAGE_DETAILS_PythonInterp:INTERNAL=[/usr/bin/python][v3.3.2()] FIND_PACKAGE_MESSAGE_DETAILS_PythonLibs:INTERNAL=[/usr/lib64/libpython2.7.so][/usr/include/python2.7][v()] PYTHON_INCLUDE_PATH:INTERNAL=/usr/include/python2.7 Leading to syntax errors during building as the Python code uses version 2 syntax: [paulm@saralt0169:~/c/vtk-6.1.0-release]$ make Scanning dependencies of target VTKData [ 0%] Built target VTKData Scanning dependencies of target zope [ 1%] Copying zope files [ 1%] Compiling Python files Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/__init__.py'... Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/_compat.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/_flatten.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/adapter.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/advice.py'... Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/idatetime.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/interfaces.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/mapping.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/sequence.py'... Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/tests'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/tests/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/tests/basemapping.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/common/tests/test_idatetime.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/tests/test_sorting.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/tests/test_verify.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/zope/interface/verify.py'... [ 1%] Built target zope Scanning dependencies of target Twisted [ 1%] Copying Twisted files [ 1%] Compiling Python files Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/_version.py'... Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/app.py'... *** File "/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/app.py", line 67 except ImportError, e: ^ SyntaxError: invalid syntax Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/internet.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/reactors.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/service.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/application/strports.py'... Listing '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults'... .... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/__init__.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/client.py'... *** File "/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/client.py", line 127 print command ^ SyntaxError: invalid syntax Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/colors.py'... Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/helper.py'... *** File "/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/helper.py", line 101 exec '%s = object()' % (keyID,) ^ SyntaxError: invalid syntax Compiling '/home/paulm/c/vtk-6.1.0-release/Wrapping/Python/twisted/conch/insults/insults.py'... | ||||||||
Project | TBD | ||||||||
(0032304) David Gobbi (developer) 2014-02-07 11:05 |
I'll look into this, because it will become an even more serious issue in the future as python3 becomes the default on more systems. The FindPythonInterp.cmake script is owned by cmake, rather than by VTK, so I'll have to test its capabilities for selecting a specific python version. |
(0033487) Ben Boeckel (Kitware) (developer) 2014-10-02 13:05 |
My recommendation is basically that CMake should treat Python2 and Python3 as different languages and support finding both at the same time (rather than the current interpreter/library split). |
(0033502) David Gobbi (developer) 2014-10-02 13:53 |
Finding both is good. Going further than than, e.g. wrapping both simultaneously as separate languages seems like a lot of work. It is something that only package maintainers would care about. My first shot at this bug will simply warn if the Libs and Interp don't match. Later we can merge the find macros. |
(0033562) David Gobbi (developer) 2014-10-02 21:52 |
http://review.source.kitware.com/17488 [^] |
(0033594) David Gobbi (developer) 2014-10-06 08:56 |
commit 52a5b9778912aca4568004453507688e6b58e11d Author: David Gobbi <david.gobbi@gmail.com> Date: Thu Oct 2 19:40:12 2014 -0600 14552: Check python interp and lib versions. Change-Id: I0c555c01deb7d6fa9a4f57d65ff5125463de7aef |
2014-01-31 09:28 | Paul Melis | New Issue | |
2014-02-07 11:05 | David Gobbi | Note Added: 0032304 | |
2014-02-07 11:05 | David Gobbi | Assigned To | => David Gobbi |
2014-02-07 11:05 | David Gobbi | Status | backlog => active development |
2014-10-02 13:05 | Ben Boeckel (Kitware) | Note Added: 0033487 | |
2014-10-02 13:53 | David Gobbi | Note Added: 0033502 | |
2014-10-02 21:52 | David Gobbi | Note Added: 0033562 | |
2014-10-02 21:52 | David Gobbi | Status | active development => gerrit review |
2014-10-06 08:56 | David Gobbi | Note Added: 0033594 | |
2014-10-06 08:56 | David Gobbi | Status | gerrit review => closed |
2014-10-06 08:56 | David Gobbi | Resolution | open => fixed |
2014-10-06 08:56 | David Gobbi | Fixed in Version | => 6.2.0 |
