0014548 | ParaView | (No Category) | public | 2014-01-29 13:08 | 2014-08-29 11:00 | ||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014548: Exodus Title string not accessable | ||||||||
Description | I have a user that would like access to the Title string in an Exodus file. It would be nice to display this in the Information tab, as well as have a way to display it on the 3d screen as text. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
Relationships | ||||||
(0032236) Alan Scott (manager) 2014-01-29 20:31 |
I am sending a file to Utkarsh named t_supg_quad.e-doNotRelease that can be used to implement and test this feature. |
(0032437) Ben Boeckel (Kitware) (developer) 2014-02-28 16:44 |
See <http://review.source.kitware.com/#/t/4018/>. [^] This adds the title as a field data array (Use the Spreadsheet view then select "Field Data"). There is a way to use this data for rendering, but Utkarsh knows more about that. |
(0032474) Ben Boeckel (Kitware) (developer) 2014-03-10 19:47 |
On master, I am seeing a "Title" Field Data item with Exodus files. |
(0032735) Alan Scott (manager) 2014-06-03 21:43 |
This functionality now works. However there is a warning that comes up. * Linux, local server, master (about a week ago) * Load data t_supg_quad.e-doNotRelease. All vars on. Apply. * AnnotateGlobalData filter. Output message will be printed. Output message states "Error while loading views/views PythonView". This needs to be fixed before this bug is closed. |
(0032746) Ben Boeckel (Kitware) (developer) 2014-06-04 16:49 |
The PythonView error isn't related to this branch; it shows up in other contexts as well (e.g., http://open.cdash.org/testDetails.php?test=256266075&build=3358357 [^]). It should be fixed, but shouldn't hold up this unrelated bug. |
(0032778) Utkarsh Ayachit (administrator) 2014-06-08 12:09 |
I've already reported another bug for that issue: BUG 0014787 |
(0032833) Alan Scott (manager) 2014-06-10 21:48 |
Tested master, Linux, local server. Remote server fails with bug number http://www.paraview.org/Bug/view.php?id=14771 [^] |
2014-01-29 13:08 | Alan Scott | New Issue | |
2014-01-29 20:31 | Alan Scott | Note Added: 0032236 | |
2014-02-27 15:35 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
2014-02-28 16:44 | Ben Boeckel (Kitware) | Note Added: 0032437 | |
2014-03-10 19:47 | Ben Boeckel (Kitware) | Note Added: 0032474 | |
2014-05-12 11:55 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-05-12 11:55 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-05-12 11:55 | Utkarsh Ayachit | Resolution | open => fixed |
2014-05-12 11:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-03 21:43 | Alan Scott | Note Added: 0032735 | |
2014-06-04 16:49 | Ben Boeckel (Kitware) | Note Added: 0032746 | |
2014-06-08 12:09 | Utkarsh Ayachit | Note Added: 0032778 | |
2014-06-08 12:10 | Utkarsh Ayachit | Relationship added | related to 0014787 |
2014-06-10 21:48 | Alan Scott | Note Added: 0032833 | |
2014-06-10 21:48 | Alan Scott | Status | customer review => closed |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
