0014546 | ParaView | (No Category) | public | 2014-01-29 11:08 | 2014-08-29 11:00 | ||||
Reporter | Dan Lipsa | ||||||||
Assigned To | Dan Lipsa | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014546: Move options for RenderView into the PropertiesPanel. | ||||||||
Description | Aditional view changes: MultiSlice, QuadView, MantaView, PrismPlugin Fixed tests that accessed ActiveRenderViewOptions. Branch name: view-settings | ||||||||
Project | TBD | ||||||||
Topic Name | view-settings | ||||||||
(0032250) Dan Lipsa (developer) 2014-01-30 10:10 |
commit 4620cc43c9687b686df5a17cd86ce3184725129d Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 29 16:29:08 2014 -0500 Remove scrolling to fix BackgroundLights test. This is because the test machine has a different resolution? Change-Id: I6153a318d797b194cb41ba5ccc41a80b1f94b3d8 commit 1b28494e0fd3e7f32a733d6f5601928dad822190 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 29 10:51:41 2014 -0500 Re-enable Xdmf tests and add a new test BackgroundLights. Xdmf test were testing a variable never set. We enable and upgrade those tes Change-Id: Ib2c48f3b2ea1c92780bc46691047b617fd9a9470 commit 17b7b21cc8a6a655668a49025ae2dec4ff7e07de Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 29 10:07:09 2014 -0500 Use the LightKit as default on the server manager. The LightKit was already used as default in Paraview, but this default was s Change-Id: I0fab3a003b13fa39d27e012a3bf9277672b4d791 commit 2cbe90ac0d79a877e9530b81d1329c5212839cfd Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Jan 27 13:47:19 2014 -0500 Hide Camera properties in the PropertiesPanel for MantaView Change-Id: Ida3fe6c8686527cdc034b3b0c8f6195b315b30b9 commit dda7343e4c4821aee8886b8f2a5992b320bea205 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Jan 27 13:34:46 2014 -0500 Fix a test that fails as a result of view properties moved to PropertiesPane Change-Id: I673adfd3130a19946a4d08f360604a5ec79c043a commit 055965b33cf283577da356ce1f40396fba651be3 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Fri Jan 24 15:43:41 2014 -0500 Fix tests that fail as a result of view properties moved to PropertiesPanel Change-Id: Iaf679835331195c1dcaaf316fac7b50ef95119e3 commit 76dd1c9151f2ebfe2d7c1eac3875f946e9fe5a35 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Fri Jan 24 14:10:17 2014 -0500 Fix export macro for Windows Change-Id: I188205bf600cc756e1e471fd5456ddaf09aac7f2 commit ed6c98c8e8c20bdd5d2000bebd7685a96f2adfbb Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Fri Jan 24 13:54:55 2014 -0500 Fix for cdash compilation errors. Change-Id: I2f4b9a2e88c72052dede0df6ddffd1e364646437 commit 883f25c9829ac6dd9bfae1529ad616ee14cc58ce Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Fri Jan 24 13:17:23 2014 -0500 Fix cdash compile warnings and Windows link error. Change-Id: Ie4d83d4e026d6cae418dd52904f556a7470c7b00 commit 8664ab6f3fe8a3ce4cc1b2cfdf579b2af37e63aa Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Jan 23 15:00:54 2014 -0500 Remove testing of 'Camera Parallel Projection' from pv.UndoRedo6 Because of moving of RenderView settings into the Properties Panel, 'Camera Parallel Projection' is not saved into the undo stack (bug 14534). A new test for this will be added when the bug will be fixed. We updated the test image so that it reflects a perspective projection. Change-Id: Id834ee52603088a35517f5448efc5645cd5305e7 commit 3dbcdaf2399ce575f02794416c470bbbab7133ea Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 22 17:12:53 2014 -0500 Rename SMPythonTesting to smtesting See commit bf42bb840bd2f9147859c292f9fa2f5d2f6c3b51. Not sure why this test did not fail earlier. Change-Id: I02234784119bccf77cf1c8b5077e67b17311a42f commit d17b34c0694782e237242e33e4e785bd8dd8e30d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Jan 22 11:10:28 2014 -0500 Fixed issues with undoing view deletion. The problem was stemming from the fact that properties on subproxies were be modified when the parent proxy was reading XML and setting iVar on subproxy properties such as PanelVisibility. Fixed by telling the subproxy to ignore property changes while the XML is being processed. Change-Id: I42981266f5ff53eee80c09f39ea490857bc6ece1 commit 139c216a423aecf224b3dd201c1e770909189ea7 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 15 13:17:18 2014 -0500 Move options for RenderView into the PropertiesPanel. Aditional view changes: MultiSlice, QuadView, MantaView, PrismPlugin Fixed tests that accessed ActiveRenderViewOptions. Change-Id: Ie6f29eb338a7e462b27890d88dd2b874d144925b commit 0e8c8a7de36b6f2a49a4a64bc51e0057dbf0b7fd Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Wed Jan 15 09:55:02 2014 -0500 Query the 'name' attribute if 'function' is not defined for a Property. When defining a pqPropertyWidget subclass for a PropertyGroup, the 'function' attribute of the Property element is used to specify the functionality queried by the custom widget. This allows to use the same custom widget for different property groups. However this also forces one to define the 'function' attri Change-Id: I57b75c4fcfe3201eb615f29e258303f7a7937335 commit 2f9285ba69f25bc1985a3c6e3bb17962570737c1 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Jan 13 09:23:42 2014 -0500 Fix typo Sceenshots -> Screenshots Change-Id: Icf250eb057a181e92aa863c90a67e7f824f49531 vtkPVRenderView::UseInteractiveRenderingForSceenshots is renamed to vtkPVRenderView::UseInteractiveRenderingForScreenshots |
(0032280) Dan Lipsa (developer) 2014-02-05 10:40 |
commit 42de1bb4dff7221728e3f10aee53987e5565f48a Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Tue Feb 4 10:38:31 2014 -0500 Remove BackgroundLights test from Mac OS X This test uses the color dialog which is different on Mac OS X. Change-Id: Ic61dcabb246804a7735036b3b5c4f8d4d8c902d9 commit 4b4d7b237da62e59400c05a722e465839ed69c95 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Feb 3 13:29:16 2014 -0500 Fix tests for modified dialogs. Change-Id: I33495b5c851966f5b21b350e93f1ce567caa574e commit 0e533d04abe43475499084f7d6e83619e8b0938f Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Feb 3 10:26:37 2014 -0500 Solve alignment and naming issues in Background and Lights editors. Change-Id: I52eb6a6d6d9f385c95ee6f5e1e8e4dada5c50502 commit d20b6c9ed4b5e6976e189af2f907323e946d4d45 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Feb 3 09:34:42 2014 -0500 Improve coverage for pqBackgroundEditorWidget.cxx Change-Id: I39929630319d4a87f5f3dcbaa6787a1000eb9f81 |
(0032303) Utkarsh Ayachit (administrator) 2014-02-07 08:09 |
SUMMARY --------------------------------------------- Topics merged into master: 14498-crash-delete-value 14540_fix_disappearing_columns 14544_temporal_xdmf 14545_parallel_python_import_paraview.simple add-paraview-config add-rendering-base-edition catalyst-web-metadata-add-on fix-catalyst-script fix_parallel_amrconnectivity make_subclassing_easier view-settings --------------------------------------------- Topics reverted from next: visit-bridge-update-2.7.0 visit-bridge-update-2.7.0-revert |
(0032371) Alan Scott (manager) 2014-02-21 15:26 |
Developer tag in git. Closing. |
(0032373) Alan Scott (manager) 2014-02-21 15:32 |
My bad. Should have been tested. |
(0032374) Alan Scott (manager) 2014-02-21 15:47 |
This feature was documented in the kitware blog http://www.kitware.com/blog/home/post/621 [^] |
(0032378) Alan Scott (manager) 2014-02-21 20:34 |
Now I have looked at the Properties tab. Looks nice. |
(0032379) Alan Scott (manager) 2014-02-21 20:35 |
Also, I tested it Linux, remote server, master. |
2014-01-29 11:08 | Dan Lipsa | New Issue | |
2014-01-29 11:08 | Dan Lipsa | Assigned To | => Dan Lipsa |
2014-01-29 11:09 | Dan Lipsa | Status | backlog => gatekeeper review |
2014-01-29 11:09 | Dan Lipsa | Resolution | open => fixed |
2014-01-29 11:15 | Dan Lipsa | Status | gatekeeper review => active development |
2014-01-30 10:10 | Dan Lipsa | Note Added: 0032250 | |
2014-01-30 10:10 | Dan Lipsa | Status | active development => gatekeeper review |
2014-02-05 10:30 | Dan Lipsa | Topic Name | => view-settings |
2014-02-05 10:40 | Dan Lipsa | Note Added: 0032280 | |
2014-02-07 08:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-02-07 08:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-07 08:09 | Utkarsh Ayachit | Note Added: 0032303 | |
2014-02-21 15:26 | Alan Scott | Note Added: 0032371 | |
2014-02-21 15:26 | Alan Scott | Status | customer review => closed |
2014-02-21 15:32 | Alan Scott | Note Added: 0032373 | |
2014-02-21 15:32 | Alan Scott | Status | closed => customer review |
2014-02-21 15:47 | Alan Scott | Note Added: 0032374 | |
2014-02-21 20:34 | Alan Scott | Note Added: 0032378 | |
2014-02-21 20:34 | Alan Scott | Status | customer review => closed |
2014-02-21 20:35 | Alan Scott | Note Added: 0032379 | |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
