0014522 | ParaView | (No Category) | public | 2014-01-16 16:58 | 2014-08-29 11:00 | ||||
Summary | 0014522: Clean properties panels for Charts | ||||||||
Description | Properties panels on charts currently use old style panels. These need to be updated. This will address the idiosyncrasies with these panels. | ||||||||
Project | Sandia | ||||||||
Topic Name | fix_chart_panels | ||||||||
Relationships | |||||||||||
(0032312) Utkarsh Ayachit (administrator) 2014-02-13 11:56 |
commit fee845bfc0790f62dfff3331025c6431b034bba3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Feb 13 11:47:19 2014 -0500 Disable render-server test for PlotOverTimeAutoApply. Since it uses surface selection which is not supported in render-server mode, disable PlotOverTimeAutoApply in that configuration. Change-Id: Ie8ee0150cd3d613e53e0a1e2b03ed552351d80e4 commit fb2e0a22ae7e062ab73e9cd215f0283faaf88a99 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Feb 13 11:22:19 2014 -0500 BUG 0013773. Fixed auto-apply issues with plot-selection-over-time. pqSelectionInputWidget was setting up the default value for the selection input using a timer. That was happening after the auto-apply timer timed out. Thus, the apply would happen before the value was set, resulting in the default for the representation being setup incorrectly. That meant no data would be shown even the selection-input was setup immediately after when the timer expired. This fixes that issue by ensure that pqProxyPropertyWidget explicitly does the initialization and removing the timer logic from pqSelectionInputWidget. Also added a test to test this. Change-Id: I6b51801e362b0cbc9aec4a7a370db0b6f32adcb2 commit ce203cb7eb26550eb01ad4973d50b90c0a316d1c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Feb 13 11:03:54 2014 -0500 BUG: Fix errors in static builds. On static build dashboards, since StreamingParticles plugin is auto-loaded, ParaView was raising error when loading AMR datatsets. vtkStreamingParticlesRepresentation was incorrectly indicating that it can't support AMR datasets. Any representation added to "GeometryRepresentation" is required to support all datatypes that GeometryRepresentation supports. Fixed that. Change-Id: Ic17d25768c62ce634249259d016d7796fd18e71f commit bb02ab64504da3474c50ccca9f537e7c20aafa9f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 11 23:53:47 2014 -0500 Fix autoapply issue. AutoApply was starting separate singleShot(..) calls instead of using a single timer instance. This was causing weird issues on OsX with PlotSelectionOverTime when AutoApply was ON. Fixed that. Change-Id: Ic6917f301df0db75e194df7364b007d333dd2ae6 commit 0a020e8be91c0b7f3f330b29102b0f91baac4664 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 11 12:05:15 2014 -0500 Fixed more unused variable warnings. Change-Id: I19fe45f6857cc1201899981bba763e81dc663740 commit e39efad46b7ba896b744557caf63cc9a0987581d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 11 11:58:44 2014 -0500 Fixed warnings with shadowed variables. Change-Id: I610e68c34134a589d25771a32fae55fdf0cc6b06 commit 11f833d9a62c707bba133d34e216a03dc8e79583 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Feb 11 09:46:50 2014 -0500 Update test to potentially work better on Windows. We need to fix the trace recording/playback for pipeline browser to more reliable. Change-Id: I33ba0594031b9f86f705041702c264b2cfd77fbb commit b3538a428c5abd5402cfc87fece845f27603932c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 16:13:38 2014 -0500 COMP: Fixed warnings Change-Id: Ief3f927ce032f38ef302237dc86d08d6729018e5 commit c6d017a45f4d9587ea56668a7145d5d4bb8186f1 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 16:00:38 2014 -0500 Increase test thresholds. Change-Id: I4742b7ceeb9b671113cee57a20506c3622490b28 commit 11efa2246b116748be2631ddf1b311c303d79ab9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 13:28:46 2014 -0500 Add selection toggling context menu to pqSeriesEditorPropertyWidget. Change-Id: I885810872f13de7441dc527d6422bccf2b88983c commit b80bc49c80c453f6cb4d13e36a4609093919f2a4 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 11:48:37 2014 -0500 Make test playback a little more consistent. Change-Id: I9c174fd0161367496b7920f84a90e44a17e54be7 commit 8984354920d8b06b0a5865cdc72bfc0c0e03f47b Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 11:06:11 2014 -0500 Fix LineChartSelection test. Change-Id: Ifcc151999dcf1e1a274a7637d73dcc136ec01ede commit f3b3697d1b924038d05164dd32614851d989fd49 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 10 11:05:22 2014 -0500 Fix interaction and locking of ranges. Charts were ignoreing interaction since on interaction the axes ranges were no locked. Fixed that. Lock axes ranges on interaction. Change-Id: I632850d6421ab3fdb4f0110dde7cbe6852103091 commit ca3eece086b04240ac2453b7febbf6e5b2b7b0f6 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Feb 9 18:33:39 2014 -0500 Fix/Update tests after chart refactoring. Updating/Fixing tests. XYChart and XYHistogram tests have now been expanded to test some components of the display panel better, including composite datasets and changes in available arrays. Change-Id: Ic4ee83049ae13420f23101591e9b31db8c6f3139 commit bead7d4044f956db5615c8290681e336a50a20be Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Feb 9 18:32:08 2014 -0500 Cleanup chart axis range reset logic. Every time the view is updated, we recalculate the chart axis ranges. The recalculation logic respects the case when user has "fixed" the axis range so it's not a problem to do this on every update. This ensures that over time and when new series are added/removed, the axis range is update automatically. Change-Id: I4a3a706ee391d62177f9211c7371325d580e6365 commit d485cfb912d5b5d5e71cb3c481ad6724a290d398 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Feb 9 18:31:03 2014 -0500 Change color assignment logic. Make each vtkSMChartSeriesSelectionDomain instance pick its own instance of vtkColorSeries. Change-Id: I909e22d59cbb0751361d77e98f71deea78867b95 commit 4c50e35a84df2d810230351c101fc893bb3a0ce3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Feb 9 16:52:27 2014 -0500 Update pqSLACManager after chart changes. Updating pqSLACManager to use the new chart representations for setting up default values appropriately. Change-Id: I51134d1f97059eaa87b41824e007f5f077343654 commit b678de8f214fa0687470acaa92d55ab4f486b693 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Feb 9 16:19:24 2014 -0500 BUG: vtkSMChartRepresentationProxy was chosing incorrect default. When known arrays were not available, vtkSMChartRepresentationProxy still erroneously chose to use the array instead of index due to a typo/copy-paste error. Fixed that. Change-Id: I174c5b3b449cd8f9e844478af724dd8fb9eebdaf commit e8d21cef5501c1eb91b0f32119245ab8a6424ab6 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 7 17:31:29 2014 -0500 Remove unnecessary drag/drop overrides. They were added in past for supporting drag/drop in scatter plot. That code has been revised. Cleaning this up since I am not sure why this was needed in the first place. Change-Id: I8525ae7b17c5557a71d32608147b11ba490bbc9d commit 85ce09f782011000321ab2eab2e6ede5204c7f35 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 7 17:16:37 2014 -0500 Enable multi-selection in pqSeriesEditorPropertyWidget. pqSeriesEditorPropertyWidget now allows users to select multiple rows and change series properties for all of them. Change-Id: Ic00566ba97207a554a71f9905cd0b7005e5a2571 commit c3ef157139a009b246140b3a9c0008ea599edd71 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 7 16:52:27 2014 -0500 Fix segfault in comparative chart views. pqComparativeContextView was overriding appropriate methods on the superclass. Fixed that. Change-Id: I5fffe88792c8e0d57351f28449011de72d242ad7 commit 74a9a6e5a1278041d1eca17a7bc09a117e308cc9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Feb 6 17:57:51 2014 -0500 Add support for cases when series-domains change. When the domain for property with a vtkSMChartSeriesSelectionDomain changes, we need to update the property to reflect the change. This implementation handles it as follows: + vtkSMChartSeriesSelectionDomain has 'experimental' logic to update the property values to reflect the domain change. + pqSeriesEditorPropertyWidget uses a filtering mechanism to filter out rows for series that are not currently in domain to avoid the table from getting too big. + Also includes some cleanup to pqSMAdaptor to speed up certain 'get' calls. Change-Id: Iebbf9669d981bcd394d02b0fce588d88464950da commit d36f8fd5669ebdae8955bfe35b36ed26c05c0b46 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jan 2 14:29:33 2014 -0500 Added auto-sizing QTableView subclass. Added a pqTableView which is a QTableView subclass that can resize its height based on the number of rows in it in an attempt to avoid to adding scroll bar for not too long a list of rows without always taking up space when there are fewer items in the table. Change-Id: I08223820d0e5a67ce75d5dc6c0c30b51fba69c1d commit eeff246949c8306e457d2e87b15af11331d10fda Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jan 2 10:45:46 2014 -0500 Cosmetic changes to pqSeriesEditorPropertyWidget. Avoid the ugly and fairly annoying horizontal scroll bar. Also changed row heights to add a little padding for better readability of text. Change-Id: Ia06de3e5a64b5f957357f40b580c1b3e215d9657 commit 678309078c95a3b3925f44f1cf1368f702efe27e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Jan 1 16:23:32 2014 -0500 Cleanup logic for setting default values. Added mechanism on vtkSMProxy to set default values for all properties that pqProxy now uses when a new proxy is created. We still have a few hacks lurking around for dealing with compound proxies in pqPipelineSource. Added support in vtkSMChartRepresentationProxy to correctly set UseIndexForXAxis property's default value based on what XArray is picked. Change-Id: If7e4ba6d40541e501a5524d2bbe55be8f992d646 commit a1cc509a3f19729e17d0e3ee496916d44b76f5c3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Jan 1 13:39:17 2014 -0500 Switching series widget to be a pqTreeView. pqTreeView is more compact than QTableView. Also fixed pqTreeView to avoid showing a vertical scroll bar for a configurable number of rows. Change-Id: Id0de77ede659e0df1f6b51179810c586c8fe1bd5 commit b8fb82758fc347b9d19750ee78ebb233fbd19a58 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Dec 28 17:19:18 2013 -0500 Fixed issue with histogram display panel. The "X" array wasn't showing up correctly on the histogram panel. The problem was that pqStringVectorPropertyWidget didn't setup hooks to monitor the domain to update the available values in the combox-box. Fixed that. Change-Id: I3f2e08156ca99b4a9db2aca28a84897b1a109d3a commit 1166c794ce339a569c7cf3503a6a23d311c21b86 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 3 18:25:05 2013 -0400 Refactoring 2D chart representations. The primary objective of this refactor is to remove custom display panels for charting views such as line/bar/scatter-plot-matrix/parallel-coordinates views and migrate these panels to the new style as required by the unified Properties panel added in ParaView 4.0. The secondary object is to move logic for setting up defaults etc. to the ServerManager layer rather than in VTK or Qt world, so that the representations behave consistently in pvpython and ParaView-GUI. This is achieved as follows: + New domains are added (vtkSMChartSeriesListDomain and vtkSMChartSeriesSelectionDomain) which can be used on properties pertaining to series in a plot e.g. SeriesVisibility, SeriesColor etc. These domains automatically keep themselves up-to-date when new arrays are added or removed due to other state changes. Like other domains in ParaView, these only depend on the data-information available on the client-side. + vtkChartNamedOptions and vtkXYChartNamedOptions are removed. Instead vtkChartRepresentation subclasses take over the responsibility of managing series parameters. vtkXYChartRepresentation is suitable for vtkChartXY views which accept vtkPlot subclasses. + vtkChartRepresentation is refactored to simplify data-delivery logic. Also added a new REQUEST_RENDER pass to vtkPVContextView which allows chart representations to update the vtk objects properly thus separating data related operations from appearance related operations. + pqChartSeriesSettingsModel represent the table-widget used for presenting user with the available series and changing their properties. Based on properties available on the proxy, pqChartSeriesSettingsModel can adapt its UI to show as few or as many widgets as needed. pqChartSeriesSettingsModel is used for all 2D views, thus we no longer need separate pqChartSeriesSettingsModel and pqPlotSettingsModel which have been removed. + vtkPVPlotMatrixRepresentation now respects order specified by the user on the SeriesVisibility property. The UI no longer hacks the order changes (which were not preserved in state files or undo/redo stacks), instead updates the property appropriately. Same can be done for vtkPVParallelCoordinatesRepresentation, but missing API on vtkPVParallelCoordinatesRepresentation keeps that from actually working, for now. + Refactored logic for dealing with multiblock-of-tables. The mechanism for naming/addressing tables in a multiblock dataset has also changed to make it easier to read. vtkChartRepresentation makes it easier for subclasses to work with multiblock of tables (e.g. vtkXYChartRepresentation) or a single vtkTable (vtkPVParallelCoordinatesRepresentation, vtkPVPlotMatrixRepresentation). A few side effects: + New arrays that become available are no longer shown automatically. The onus falls on the appplication layer to manage their visibility/appearance. Work in progress to update UI when new arrays become available. Change-Id: I6531f85a2167c73d98dbb28edf7aa3cc32031111 commit 42fb9819dae1b07004bfbe08774677938d161042 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Dec 28 02:30:37 2013 -0500 Added mechanism to easily determine block-name. Added mechanism to vtkPVDataInformation to easily determine block name i.e. the vtkCompositeDataSet::NAME() for a block in a composite dataset. Change-Id: Iee25295d6fd4603f85c6b218cfff9cdc794209fb commit 137344fcb6b64b3d61a8e59e3b10d7f40a09259c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Dec 28 02:29:48 2013 -0500 Remove unnecessary shallow copy. Minor cleanup, removed unnecessary shallow copy. Change-Id: I5e08407c50c9c3e543aaca3e7e487fc34f255293 commit 76b12864720ae41a7b064747574138f0386e51ce Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Dec 28 02:28:42 2013 -0500 vtkPVMergeTablesMultiBlock wrongly added empty tables to output. vtkPVMergeTablesMultiBlock ended up adding empty vtkTable instances to the output with a particular location was empty on all input composite datasets. Fixed that. Change-Id: I3e0aab158b3740f6f62ecdb0386af0bb30d682a8 |
(0032333) Utkarsh Ayachit (administrator) 2014-02-15 08:58 |
Topics merged into master: 14511-qt5-support assembly-exporter catalyst-rendering-fix easy_subclassing fix_chart_panels fix_parallel_amrconnectivity remove_duplicate_pqColorTableModel robust_pca view-settings visit-bridge-update-2.7.0 |
(0032401) Alan Scott (manager) 2014-02-24 13:02 |
Tested Linux, local server, master. Looks nice - specifically the ability to plot multiple cells at at time. |
2014-01-16 16:58 | Utkarsh Ayachit | New Issue | |
2014-01-16 16:58 | Utkarsh Ayachit | Relationship added | parent of 0013917 |
2014-01-16 16:58 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-01-16 16:58 | Utkarsh Ayachit | Relationship added | parent of 0013898 |
2014-02-07 21:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-02-07 21:48 | Utkarsh Ayachit | Status | backlog => active development |
2014-02-13 11:56 | Utkarsh Ayachit | Topic Name | => fix_chart_panels |
2014-02-13 11:56 | Utkarsh Ayachit | Note Added: 0032312 | |
2014-02-13 11:56 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-02-13 11:56 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-02-13 11:56 | Utkarsh Ayachit | Resolution | open => fixed |
2014-02-15 08:58 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-02-15 08:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-15 08:58 | Utkarsh Ayachit | Note Added: 0032333 | |
2014-02-24 13:02 | Alan Scott | Note Added: 0032401 | |
2014-02-24 13:02 | Alan Scott | Status | customer review => closed |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
