0014512 | ParaView | (No Category) | public | 2014-01-13 17:23 | 2015-01-11 08:21 | ||||
Summary | 0014512: Add error output for connections, debug build | ||||||||
Description | Please add error output prints for failed connections, debug builds only. As per Utkarsh, this needs to occur on both the client and server side. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14512_print_info_on_handshake_failure | ||||||||
(0032193) Utkarsh Ayachit (administrator) 2014-01-21 09:48 |
commit fd3b47f8bc4171f334b4749313021a182d26e52b Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jan 21 09:45:50 2014 -0500 BUG 0014512: Print debug info when connection fails. If a client-server connection handshake fails, it can be tricky for users to determine exactly what went wrong. To make it easier, each process now prints out information on the standard output providing information about that process such as the handshake used by that process, the socket communicator vesion number. The user can then compare the values printed out on the client and server side to deduce why the connection failed. Change-Id: Ib7f2adf477abf2cc865f55870dbf87de7557f029 |
(0032194) Utkarsh Ayachit (administrator) 2014-01-21 09:48 |
The result looks like the following: On client: ---------------------------------- ERROR: In /home/utkarsh/Kitware/ParaView3/ParaView/ParaViewCore/ClientServerCore/Core/vtkTCPNetworkAccessManager.cxx, line 340 vtkTCPNetworkAccessManager (0x11be370): ********************************************************************** Connection failed during handshake. This can happen for the following reasons: 1. Connection dropped during the handshake. 2. vtkSocketCommunicator::GetVersion() returns different values on the two connecting processes (Current value: 100). 3. ParaView handshake strings are different on the two connecting processes (Current value: paraview.4.1). ********************************************************************** On server: ------------------- ERROR: In /home/utkarsh/Kitware/ParaView3/ParaView/ParaViewCore/ClientServerCore/Core/vtkTCPNetworkAccessManager.cxx, line 424 vtkTCPNetworkAccessManager (0x90f910): ********************************************************************** Connection failed during handshake. This can happen for the following reasons: 1. Connection dropped during the handshake. 2. vtkSocketCommunicator::GetVersion() returns different values on the two connecting processes (Current value: 100). 3. ParaView handshake strings are different on the two connecting processes (Current value: paraview.4.1.connect_id.12). ********************************************************************** |
(0032242) Utkarsh Ayachit (administrator) 2014-01-30 08:29 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14508-title-bar 14512_print_info_on_handshake_failure add-rendering-base-edition (VTK) enable-new-vtk-image-filters fix_parallel_amrconnectivity fix_tiff_dependency_issues popout_tabwidget pvweb-apache-doc-fix pvweb-fixes rescale_over_time_bug sqtk-refactor-fixes (VTK) sticky-axes view-settings (VTK) web-catalyst-module-update |
(0032267) Alan Scott (manager) 2014-02-04 21:18 |
Excellent. Tested remote server, Linux, master. |
2014-01-13 17:23 | Alan Scott | New Issue | |
2014-01-21 09:48 | Utkarsh Ayachit | Topic Name | => 14512_print_info_on_handshake_failure |
2014-01-21 09:48 | Utkarsh Ayachit | Note Added: 0032193 | |
2014-01-21 09:48 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-01-21 09:48 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-01-21 09:48 | Utkarsh Ayachit | Resolution | open => fixed |
2014-01-21 09:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-01-21 09:48 | Utkarsh Ayachit | Note Added: 0032194 | |
2014-01-30 08:28 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-01-30 08:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-01-30 08:29 | Utkarsh Ayachit | Note Added: 0032242 | |
2014-02-04 21:18 | Alan Scott | Note Added: 0032267 | |
2014-02-04 21:18 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 391cec74 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master fd3b47f8 |
