0014511 | ParaView | (No Category) | public | 2014-01-11 00:55 | 2014-08-29 11:00 | ||||
Reporter | Sankhesh Jhaveri | ||||||||
Assigned To | Sankhesh Jhaveri | ||||||||
Summary | 0014511: Add Qt5 support to ParaView | ||||||||
Description | Qt5 Support | ||||||||
Project | TBD | ||||||||
Topic Name | 14511-qt5-support | ||||||||
Type | feature | ||||||||
(0032323) Sankhesh Jhaveri (developer) 2014-02-13 17:37 |
commit 7db74014bae872afc70f6bcd201c2293a56cf7a3 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Tue Feb 11 17:46:12 2014 -0500 Import Qt5Widgets module at the top level This ensures all the required Qt5 variables can be found. For example, just importing Qt5Core does not help find QT_UIC_EXECUTABLE using the macro "get_target_property(QT_UIC_EXECUTABLE Qt5::uic LOCATION)". Change-Id: I8756ce9468c5134693d256a9755f1217bc24ae29 commit 0fb21b1d9ad4de75fc83536c1f3d8683532b96d6 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Fri Jan 31 12:28:30 2014 -0500 Updated QtTesting to use Qt5 QtTesting should use user selected Qt version Change-Id: I55379c00655595e567ae393d42a25baa8635b916 commit 6fa66ba56168ce6b0facec0884f199efea518c94 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 18:04:31 2014 -0500 Use the new Qt5 plugin architecture Q_EXPORT_PLUGIN2 deprecated. Replaced by Q_PLUGIN_METADATA Find the Qt5 RCC executable to generate qrc_* files. Change-Id: I407ac783071895e2f01d51d0ddd71635e54813f3 commit a59a868b22bb7b8e32a9948bc4a24138b3dc6b04 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 13:01:06 2014 -0500 QWindowsStyle and QPlastiqueStyle obsoleted Replaced with the Fusion style and the new QStyleFactory::create() API. Use style depending on Qt version used Change-Id: I3bb01c883025122a9de40b98866de6a757def047 commit 785695c00a65bc40c3a413bf4eefedad25e2ca20 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 12:59:33 2014 -0500 QtGui library -> include QtGui/* files directly Change-Id: Ia0d1e6510c014fb67986f330cd98c81f73aa17c3 commit 20c9a6346d0834d8d29ec81451dba8b539b46ba7 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 12:57:32 2014 -0500 Obsoleted constructor for QGraphicsItem Removed the use of QGraphicsScene from the constructor argument. Change-Id: Ib257adc90fbd8b810baa4d65dcbd78d5e66da9d1 commit 88cbb1f4f6fcf0936625a698cae6588e26e11f54 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 12:30:22 2014 -0500 Multiple Qt5 related minor changes 1. QCursor constructor needs QPixmap instead of const char* 2. Qt::WFlags obsoleted. Replaced by Qt::WindowFlags 3. QPixmap::serialNumber() deprecated. Replaced by QPixmap::cacheKey() 4. QVariant(Qt::GlobalColor) is now private. Use QVariant(QColor(Qt::GlobalColor)) instead. 5. QMetaMethod::signature obsoleted. Replaced by QMetaMethod::methodSignature(). To avoid runtime issues get the pointer to data using methodSignature().constData() 6. QDir::convertSeparators obsoleted. Replaced by toNativeSeparators/fromNativeSeparators 7. QRegion::unite deprecated. Replaced by QRegion::united 8. QCoreApplication::UnicodeUTF8 is deprecated. 9. Missing includes Change-Id: I1a5b889b01178f030ed97a65bb7c5ff006949bef commit dd2a9104e1aca5f92abf1a17f0b90c3a47cd1613 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 11:33:22 2014 -0500 Qt5 obsoletes toAscii and fromAscii methods Replaced all instances: QString::toAscii --> QString::toLatin1 QString::fromAscii --> QString::fromLatin1 QChar::fromAscii --> QLatin1Char Change-Id: I5107bbd7b5550ded121310314f0569246ff8bf2c commit 44530d0721395a850ce396cff8bf2b59affeecb2 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 10:57:19 2014 -0500 Compile flags (-fPIE) for position independent code Qt5 is built and packaged with the -reduce-relocations configure option as default. This causes compilations to run with the -Bsymbolic-functions option, which makes function pointer comparison ineffective, unless the -fPIE flag is also supplied. Change-Id: Ic1dead333d25b2ff17eda049b57d08db3a27f8b4 commit 7aa49510b1e29c7a8ef810bd26b8af41172364f9 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 12:20:43 2014 -0500 QAbstractItemModel::reset() and QAbstractItemModel::createIndex QAbstractItemModel::reset - The deprecated function emitted two signals, namely modelAboutToBeReset and modelReset. Using beginResetModel and endResetModel to emit these signals instead. QAbstractItemModel::createIndex - Ambiguity when compiling with gcc. When the last parameter is either NULL or 0, GCC fails to resolve which path to follow. Use the default value (void* ptr = 0) provided in the function declaration. Change-Id: I45760b1cc9d9afc183a2aed9100d7ab398f0ab65 commit eb421899dde154e5841cdaebe8a079092e7ede32 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 11:48:39 2014 -0500 Qt5 obsoletes global typedef qInstallMsgHandler and QtMsgHandler Using qInstallMessageHander and QtMessageHandler QtMessageHandler has a different signature than QtMsgHandler providing information about context. Incorporated that information in the vtkOutputWindow message printout. Change-Id: Icd94f6fc411e0761c0254a0e11784543b0cf0bd7 commit f3b59483e8493cab9e0600b394c1572d31dc17e2 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Thu Jan 30 11:43:24 2014 -0500 Obsoleted methods from QHeaderView Replaced all instances: QHeaderView::setClickable --> QHeaderView::setSectionsClickable QHeaderView::setResizeMode --> QHeaderView::setSectionResizeMode QHeaderView::setMovable --> QHeaderView::setSectionsMovable Change-Id: I537f7148abfccf4564d375475ec76b8485c31777 commit 9ed056a1aa902e249cf8ef398433a3ce6e3caaf6 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Wed Jan 15 10:03:11 2014 -0500 Modified ParaView macros to use both Qt4 and Qt5 Depending on the PARAVIEW_QT_VERSION variable value, the appropriate Qt version is used. Change-Id: I296dbc87a4ad05426bdf65e16e4bafa7bcdb8074 commit eed7ccd3f7e804fed3864fcbe54fbd6958e63b41 Author: Sankhesh Jhaveri <sankhesh.jhaveri@kitware.com> Date: Tue Jan 14 13:55:19 2014 -0500 Initial changes to support Qt5 Added a new flag called PARAVIEW_QT_VERSION that can be set to either 4 or 5. Depending on the value of this flag, the appropriate Qt version is looked for and built against. If PARAVIEW_QT_VERSION==5, the necessary Qt5 modules can be imported by including the script "ParaViewQt5.cmake". This script also sets important Qt variables used throughout the project. Setting the officially supported version of Qt5 to 5.0.2. Although, paraview compiles fine against Qt-5.0.0, there are known issues that prevent it from being fully functional (https://bugreports.qt-project.org/browse/QTBUG-28872 [^]). Setting the minimum Qt5 version to 5.0.0. Change-Id: I152529ef3da9492a44094c1e08444398a022d047 |
(0032332) Utkarsh Ayachit (administrator) 2014-02-15 08:58 |
Topics merged into master: 14511-qt5-support assembly-exporter catalyst-rendering-fix easy_subclassing fix_chart_panels fix_parallel_amrconnectivity remove_duplicate_pqColorTableModel robust_pca view-settings visit-bridge-update-2.7.0 |
(0032359) Alan Scott (manager) 2014-02-20 22:04 |
Developer tag in git. Also, trusting that nightly builds tested this. Closing. |
2014-01-11 00:55 | Sankhesh Jhaveri | New Issue | |
2014-01-11 00:55 | Sankhesh Jhaveri | Assigned To | => Sankhesh Jhaveri |
2014-01-11 00:55 | Sankhesh Jhaveri | Status | backlog => todo |
2014-02-13 17:37 | Sankhesh Jhaveri | Topic Name | => 14511-qt5-support |
2014-02-13 17:37 | Sankhesh Jhaveri | Note Added: 0032323 | |
2014-02-13 17:37 | Sankhesh Jhaveri | Status | todo => gatekeeper review |
2014-02-13 17:37 | Sankhesh Jhaveri | Resolution | open => fixed |
2014-02-15 08:58 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-02-15 08:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-15 08:58 | Utkarsh Ayachit | Note Added: 0032332 | |
2014-02-20 22:04 | Alan Scott | Note Added: 0032359 | |
2014-02-20 22:04 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
