0014496 | ParaView | (No Category) | public | 2014-01-02 11:32 | 2015-01-11 08:20 | ||||
Reporter | Sebastien Jourdain | ||||||||
Summary | 0014496: Trace does not detect sub-proxy change | ||||||||
Description | I was on OS X Mavericks when I tried that: Try the following: 1) Start ParaView 2) Start trace => You should get a python error message: Error while loading views/views PythonView 3) Source -> Wavelet => Apply 4) Slice + move plane (Normal+Origin) => Apply 5) Stop trace ==> At that point you should be able to see the slice.SliceType.Normal/Origin information. 6) Start trace 7) Move plane again and apply 8) Stop trace => At that point you don't get the new Normal/Origin, instead you get the following # -------------------------------------- try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() RenderView1 = GetRenderView() RenderView1.CameraClippingRange = [42.21504162873032, 98.18281698732744] a1_RTData_PVLookupTable = GetLookupTableForArray( "RTData", 1, RGBPoints=[42.78080368041992, 0.23, 0.299, 0.754, 159.74042320251465, 0.865, 0.865, 0.865, 276.7000427246094, 0.706, 0.016, 0.15] ) Render() # -------------------------------------- | ||||||||
Project | Sandia | ||||||||
Topic Name | 14496_fix_tracing_of_subproxies | ||||||||
(0032176) Utkarsh Ayachit (administrator) 2014-01-15 12:20 |
commit 5c20d464cd40b676b7b37fbdfa7e974f3e3a0ebd Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Jan 15 12:18:32 2014 -0500 BUG 0014496. Fixes issues with tracing certain proxy properties. When on changed helper property values e.g. the Normal for a clip plane, trace would not record it unless the creation the "Clip" filter was also captured in that trace. That was due to missing logic to "locate" the proxy being modified when the Normal was changed. This patch addresses that issue. Change-Id: I9738ed98cdd19671a708f1c8f72057bc4e43628b |
(0032188) Utkarsh Ayachit (administrator) 2014-01-20 10:01 |
SUMMARY --------------------------------------------- Topics merged into master: 14487_fix_segfault 14496_fix_tracing_of_subproxies pvweb-add-webtest-setup-doc pvweb-quick-start-doc-update |
(0032273) Alan Scott (manager) 2014-02-04 21:47 |
Looks correct to me. My Mac is tied up updating, and I believe this bug is not OS X Mavericks specific. Tested Linux, remote server, master. |
2014-01-02 11:32 | Sebastien Jourdain | New Issue | |
2014-01-02 11:32 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2014-01-15 12:20 | Utkarsh Ayachit | Project | TBD => Sandia |
2014-01-15 12:20 | Utkarsh Ayachit | Topic Name | => 14496_fix_tracing_of_subproxies |
2014-01-15 12:20 | Utkarsh Ayachit | Note Added: 0032176 | |
2014-01-15 12:20 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-01-15 12:20 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-01-15 12:20 | Utkarsh Ayachit | Resolution | open => fixed |
2014-01-20 10:00 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-01-20 10:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-01-20 10:01 | Utkarsh Ayachit | Note Added: 0032188 | |
2014-02-04 21:47 | Alan Scott | Note Added: 0032273 | |
2014-02-04 21:47 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:20 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master c8416a71 |
2015-01-11 08:20 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 5c20d464 |
