0014482 | ParaView | (No Category) | public | 2013-12-19 20:34 | 2015-01-11 08:32 | ||||
Summary | 0014482: Changes to Specular Lighting | ||||||||
Description | Here is Ken's writeup on how we will change specular lighting: I propose an alternate solution. How about we remove the "Specular Highlighting with Scalar Coloring" setting and just leave that option on all the time. Then make the default specular intensity 0. (The current default is 0.1, which is hardly noticeable anyway.) That will have the same effect as having specular highlights off by default. Also, make the specular intensity parameter non-advanced so that it is discoverable and easier to set. | ||||||||
Tags | Settings 2.0 | ||||||||
Project | Sandia | ||||||||
Topic Name | lookup_table_cleanup | ||||||||
(0032503) Utkarsh Ayachit (administrator) 2014-03-20 20:26 |
commit 5e9449c91a9fbdcd149cd93ca19ac1a1a3ff967d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Mar 20 20:25:18 2014 -0400 BUG 0014482: Fix specular lighting and scalar coloring. Based on the bug report, we no longer disable specular highlights when using scalar coloring. We just changed the default specular power to 0. Users can now change the specular power to add specular highlights. Change-Id: I75d3a62a5663bdf796d178f9d1582306f75c7af7 |
(0032638) Utkarsh Ayachit (administrator) 2014-05-16 06:50 |
See post for details: http://www.kitware.com/blog/home/post/671 [^] |
(0032720) Alan Scott (manager) 2014-06-03 20:08 |
Nice! Tested remote server, Linux, master. |
2013-12-19 20:34 | Alan Scott | New Issue | |
2014-03-20 20:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-03-20 20:14 | Utkarsh Ayachit | Status | backlog => active development |
2014-03-20 20:26 | Utkarsh Ayachit | Note Added: 0032503 | |
2014-03-20 20:26 | Utkarsh Ayachit | Tag Attached: Settings 2.0 | |
2014-03-20 20:27 | Utkarsh Ayachit | Topic Name | => lookup_table_cleanup |
2014-05-16 06:48 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-05-16 06:48 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-05-16 06:48 | Utkarsh Ayachit | Resolution | open => fixed |
2014-05-16 06:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-05-16 06:50 | Utkarsh Ayachit | Note Added: 0032638 | |
2014-05-20 07:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-03 20:08 | Alan Scott | Note Added: 0032720 | |
2014-06-03 20:08 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 326e9ea1 |
