0014456VTK(No Category)public2013-12-11 05:482016-07-07 13:36
ReporterJorge
Assigned ToAndy Bauer
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version6.0.0
Target VersionFixed in Version7.1.0
Summary0014456: unexpected behaviour with vtkParticlePathFilter when setting StartTime
DescriptionI have seen an unexpected behaviour when setting StartTime in vtkParticlePathFilter. With only one seed if I set StartTime to a value bigger that the first time-value then more than one path is generated. Here I attach a result example (vtkPolyData) to show what I mean. The two paths generated are coincident in position, the first path even repeats the seed point twice.
Tagshackaton
ProjectTBD
Typeincorrect functionality
Attached Files? file icon TestPathline_Issue004.vtk [^] (1,018 bytes) 2013-12-11 05:52
 Relationships
  Notes
(0033535)
Andy Bauer (developer)
2014-10-02 15:51
Thanks for the input. Please provide steps to reproduce the problem (include code if that's needed).
(0035357)
sreekanth (developer)
2015-10-21 14:31
documentation for vtkParticleTracer::SetStartTime is not accurate!
(0035369)
2015-10-21 15:48
Have you submitted a change for the documentation?
(0036207)
2016-07-06 13:11
Documentation for SetStartTime() fixed.
(0036228)
2016-07-06 15:52
https://gitlab.kitware.com/vtk/vtk/merge_requests/1643 [^] is gitlab MR for fixing multiple lines issue. Documentation has been updated.
 Issue History
2013-12-11 05:48 Jorge New Issue
2013-12-11 05:52 Jorge File Added: TestPathline_Issue004.vtk
2014-10-01 20:23 Berk Geveci Tag Attached: hackaton
2014-10-02 15:51 Andy Bauer Note Added: 0033535
2015-10-21 13:01 sreekanth Assigned To => sreekanth
2015-10-21 14:31 sreekanth Note Added: 0035357
2015-10-21 15:48 Andy Bauer Note Added: 0035369
2016-07-06 11:56 Berk Geveci Assigned To sreekanth => Berk Geveci
2016-07-06 11:56 Berk Geveci Assigned To Berk Geveci => Andy Bauer
2016-07-06 13:11 Andy Bauer Note Added: 0036207
2016-07-06 15:52 Andy Bauer Note Added: 0036228
2016-07-06 15:52 Andy Bauer Status backlog => active development
2016-07-07 13:36 Andy Bauer Status active development => closed
2016-07-07 13:36 Andy Bauer Resolution open => fixed
2016-07-07 13:36 Andy Bauer Fixed in Version => 7.1.0
