0014444 | ParaView | (No Category) | public | 2013-12-05 13:25 | 2014-08-29 11:00 | ||||
Reporter | Nathan Fabian | ||||||||
Assigned To | Nathan Fabian | ||||||||
Summary | 0014444: implement new fragment analysis | ||||||||
Description | extend the AMRContour filter with two new filters to do connectivity and integration, closer mimic the Material Interaface Filter. | ||||||||
Project | Sandia | ||||||||
Topic Name | fix_parallel_amrconnectivity, implement_new_fragment_analysis | ||||||||
(0031916) Sebastien Jourdain (manager) 2013-12-08 13:34 |
This branch has been reverted from next due to some Windows issue. Please push again with a fix for Windows |
(0032031) Nathan Fabian (developer) 2013-12-19 13:28 |
Adding fix_parallel_amrconnectivity branch since implement_new_fragment_analysis is already merged. |
(0032039) Utkarsh Ayachit (administrator) 2013-12-20 08:26 |
Topics merged into master: 14286_fix_orientation_widget (VTK) 14426-huge-png 14464_fix_specular_highlights 14466_fix_calculator_panel disable-unified-bindings-by-default fix-collaboration fix_parallel_amrconnectivity gio-cleanup-and-warning-fixes pvweb-enhancements-events-protocols-docs |
(0032051) Alan Scott (manager) 2013-12-24 16:22 |
Wrote an e-mail to Nathan, asking how to test. |
(0032132) Nathan Fabian (developer) 2014-01-06 12:37 |
To test basic functionality, there are two new filters under Filters->CTH, "AMR Connectivity" and "AMR Fragment Integration" Load an AMR spyplot file and bring in at least one Volume Fraction and one corresponding Mass array. Execute the AMR Connectivity on that volume fraction. Then execute the AMR Fragment Integration on the result using both the volume fraction and mass array. You should get a spreadsheet of the fragments with their mass and volume. Known issue: AMR Connectivity doesn't correctly display the region ID produced by AMR connectivity. It relies on values in the ghost cells, so I'll need to add an option to produce region ID in the ghosts. Unknown issue: Not sure if it scales well or not yet. |
(0032139) Alan Scott (manager) 2014-01-07 16:06 |
This hangs when running Dave's small cth dataset. (Ask me for it - Utkarsh should also have it). Remote server, 8 servers. Open dataset. All variables on. AMR Connectivity filter, Material Volume 1, apply. Never returns (but doesn't crash). |
(0032203) Nathan Fabian (developer) 2014-01-21 18:43 |
Okay, I found it. I've pushed to next and will mark this when the dashboards come clean. |
(0032204) Nathan Fabian (developer) 2014-01-21 19:32 |
It looks like the dashboard is clean. |
(0032235) Nathan Fabian (developer) 2014-01-29 18:33 |
Found an additional problem, working it out. |
(0032285) Nathan Fabian (developer) 2014-02-05 14:14 |
I believe this is finally resolved for various core counts. |
(0032302) Utkarsh Ayachit (administrator) 2014-02-07 08:09 |
SUMMARY --------------------------------------------- Topics merged into master: 14498-crash-delete-value 14540_fix_disappearing_columns 14544_temporal_xdmf 14545_parallel_python_import_paraview.simple add-paraview-config add-rendering-base-edition catalyst-web-metadata-add-on fix-catalyst-script fix_parallel_amrconnectivity make_subclassing_easier view-settings --------------------------------------------- Topics reverted from next: visit-bridge-update-2.7.0 visit-bridge-update-2.7.0-revert |
(0032377) Alan Scott (manager) 2014-02-21 20:33 |
I don't understand this filter set, thus will meet with Nathan next week. He can show me how it works. |
(0032418) Alan Scott (manager) 2014-02-26 22:16 |
Talked this one over with Nathan, and we agreed to push it back. To resolve this bug, we need two things: * Nathan said there is a bug where this filter doesn't work correctly at scale. * We need how to run and test this bug documented somewhere, preferably the wiki page. |
(0032534) Nathan Fabian (developer) 2014-03-25 12:30 |
It looks like this new model is working correctly. It scales okay, but needs improvement, however it should be functional. Additionally, here's a wiki page with the explanation: http://paraview.org/Wiki/ParaView/Catalyst/AMRFragments [^] |
(0032897) Alan Scott (manager) 2014-06-18 22:02 |
Needs to be tested at huge scale, which Nathan is doing. Trusting Nathan - closing untested. |
2013-12-05 13:25 | Nathan Fabian | New Issue | |
2013-12-05 13:25 | Nathan Fabian | Assigned To | => Nathan Fabian |
2013-12-05 13:51 | Nathan Fabian | Topic Name | => implement_new_fragment_analysis |
2013-12-05 13:51 | Nathan Fabian | Status | backlog => gatekeeper review |
2013-12-05 13:51 | Nathan Fabian | Resolution | open => fixed |
2013-12-08 13:34 | Sebastien Jourdain | Note Added: 0031916 | |
2013-12-08 13:34 | Sebastien Jourdain | Status | gatekeeper review => active development |
2013-12-19 13:28 | Nathan Fabian | Topic Name | implement_new_fragment_analysis => fix_parallel_amrconnectivity, implement_new_fragment_analysis |
2013-12-19 13:28 | Nathan Fabian | Note Added: 0032031 | |
2013-12-19 13:28 | Nathan Fabian | Status | active development => gatekeeper review |
2013-12-20 08:26 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-12-20 08:26 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-20 08:26 | Utkarsh Ayachit | Note Added: 0032039 | |
2013-12-24 16:22 | Alan Scott | Note Added: 0032051 | |
2014-01-06 12:37 | Nathan Fabian | Note Added: 0032132 | |
2014-01-07 16:06 | Alan Scott | Note Added: 0032139 | |
2014-01-07 16:06 | Alan Scott | Status | customer review => todo |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-01-21 18:43 | Nathan Fabian | Note Added: 0032203 | |
2014-01-21 19:32 | Nathan Fabian | Note Added: 0032204 | |
2014-01-21 19:32 | Nathan Fabian | Status | todo => gatekeeper review |
2014-01-29 18:32 | Nathan Fabian | Status | gatekeeper review => todo |
2014-01-29 18:33 | Nathan Fabian | Note Added: 0032235 | |
2014-02-05 14:14 | Nathan Fabian | Note Added: 0032285 | |
2014-02-05 14:14 | Nathan Fabian | Status | todo => gatekeeper review |
2014-02-07 08:09 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-master |
2014-02-07 08:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-07 08:09 | Utkarsh Ayachit | Note Added: 0032302 | |
2014-02-21 20:33 | Alan Scott | Note Added: 0032377 | |
2014-02-26 22:16 | Alan Scott | Note Added: 0032418 | |
2014-02-26 22:16 | Alan Scott | Status | customer review => backlog |
2014-02-26 22:16 | Alan Scott | Resolution | fixed => reopened |
2014-03-25 12:30 | Nathan Fabian | Note Added: 0032534 | |
2014-03-25 12:30 | Nathan Fabian | Status | backlog => gatekeeper review |
2014-03-25 12:30 | Nathan Fabian | Resolution | reopened => fixed |
2014-03-28 11:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-18 21:56 | Alan Scott | Project | TBD => Sandia |
2014-06-18 22:02 | Alan Scott | Note Added: 0032897 | |
2014-06-18 22:02 | Alan Scott | Status | customer review => closed |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
