0014406 | ParaView | (No Category) | public | 2013-11-13 19:13 | 2014-08-29 11:00 | ||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014406: multiblock view doesn't respect reader block selection | ||||||||
Description | I assume that blocks that are not read in should not be available to the multi-block inspector. But, it is! * 4.1.0-RC1, Linux, local server. * Open Can.exo. Only load the first block. Apply. * View/ multi-block inspector. Notice that both blocks show up. This is a bug. | ||||||||
Project | Sandia | ||||||||
Topic Name | disabled-multiblock-pieces | ||||||||
(0032417) Alan Scott (manager) 2014-02-26 16:24 |
I have a user that is asking that this be fixed. |
(0032432) Utkarsh Ayachit (administrator) 2014-02-27 15:14 |
Alan, Here's the reason why this happens. When you tell the exodus reader to read only one block, the reader outputs actual data (geometry/data attributes) only for that block, however the output structure is always full and complete -- look at the information panel to see what I am talking about. The multiblock inspector shows this structure. We could say the reader should only output blocks that are being read, but that results in the output structure changing every time the selection is changed which can cause the filters like extract block to fail. If it were up to me, I won't consider this as a bug. Let me know what you think. |
(0032433) Utkarsh Ayachit (administrator) 2014-02-27 15:15 |
customer review for feedback. Feel free to reopen. |
(0032436) Utkarsh Ayachit (administrator) 2014-02-28 10:54 |
The idea is to grey out entires when they refer to empty (or null) datasets. |
(0032442) Utkarsh Ayachit (administrator) 2014-03-03 13:17 |
Developer notes: The widget of interest is pqMultiBlockInspectorPanel. In pqMultiBlockInspectorPanel, we can check if any "leaf" node's vtkPVDataInformation is a "vtkDataSet" and has 0 cells or points, in that case, we show the item "disabled" in the widget. Ensure that this updates correctly as the user toggles the blocks that are read in from the Properties panel. |
(0032453) Ben Boeckel (Kitware) (developer) 2014-03-03 21:09 |
Pushed to stage as 'disabled-multiblock-pieces' and merged into next. |
(0032465) Utkarsh Ayachit (administrator) 2014-03-09 13:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13794_fix_mp4py 14572-search-series-parameter-widget 14620_FixRulerCrash disabled-multiblock-pieces fix_example_qt5 optimize_amrconnectivity point-sprite-plugin-crash pvweb-visualizer remove-extra-resources (VTK) update-vtk-20140303 ------------------------------------------- |
(0032527) Alan Scott (manager) 2014-03-21 15:39 |
Very nice. Tested remote server, Linux, master. |
2013-11-13 19:13 | Alan Scott | New Issue | |
2014-02-26 16:24 | Alan Scott | Note Added: 0032417 | |
2014-02-26 16:24 | Alan Scott | Status | backlog => todo |
2014-02-27 15:14 | Utkarsh Ayachit | Note Added: 0032432 | |
2014-02-27 15:15 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-02-27 15:15 | Utkarsh Ayachit | Resolution | open => fixed |
2014-02-27 15:15 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-02-27 15:15 | Utkarsh Ayachit | Note Added: 0032433 | |
2014-02-27 15:15 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-02-28 10:54 | Utkarsh Ayachit | Note Added: 0032436 | |
2014-02-28 10:54 | Utkarsh Ayachit | Status | customer review => todo |
2014-02-28 10:54 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Ben Boeckel (Kitware) |
2014-03-03 13:17 | Utkarsh Ayachit | Note Added: 0032442 | |
2014-03-03 21:09 | Ben Boeckel (Kitware) | Note Added: 0032453 | |
2014-03-03 21:09 | Ben Boeckel (Kitware) | Status | todo => gatekeeper review |
2014-03-09 13:21 | Utkarsh Ayachit | Topic Name | => disabled-multiblock-pieces |
2014-03-09 13:24 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-03-09 13:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-03-09 13:24 | Utkarsh Ayachit | Note Added: 0032465 | |
2014-03-21 15:39 | Alan Scott | Note Added: 0032527 | |
2014-03-21 15:39 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
