0014388 | ParaView | (No Category) | public | 2013-11-01 16:20 | 2015-11-04 21:31 | ||||
Assigned To | Cory Quammen | ||||||||
Summary | 0014388: Paste multiple lines into the python shell is broken. | ||||||||
Description | Linux, local server, master. Run ParaView. Tools/ Python Shell. Now, cut and paste the following into the shell. It doesn't work. try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() Sphere1 = Sphere() RenderView1 = GetRenderView() DataRepresentation1 = Show() DataRepresentation1.ScaleFactor = 0.1 DataRepresentation1.SelectionPointFieldDataArrayName = 'Normals' DataRepresentation1.EdgeColor = [0.0, 0.0, 0.5000076295109483] RenderView1.CameraPosition = [0.0, 0.0, 3.2903743041222895] RenderView1.CameraClippingRange = [2.2624705610810665, 4.592229918684124] RenderView1.CameraParallelScale = 0.8516115354228021 Render() | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0031824) Utkarsh Ayachit (administrator) 2013-11-04 11:19 |
Note: this should have been working as Pat mentioned on the mailing list: commit af99ee38d6edcefaeb5f5bd2936f0bf82bdcf565 Author: Pat Marion <pat.marion@kitware.com> Date: Fri May 24 12:23:56 2013 +1000 Change the behavior of pqPythonShell::pushScript() to split over newlines Previously, you could not paste multiline statements into the ParaView python console. This commit changes the behavior of the pushScript() function so that it splits the script code over the newline character and pushes each line separately. This does change the behavior of entering multiline statements: previously pushScript() would attempt to detect the indent and start the next line using the indent of the previous line. This behavior has been removed. The new behavior closely matches the behavior of the standard commandline python interpreter. Change-Id: I899ec69194a1cce3d82cefc2f13048aad8f81fec |
(0031910) Cory Quammen (developer) 2013-12-07 00:09 edited on: 2013-12-07 00:11 |
Hi Alan, I wasn't able to reproduce this on either Linux or Windows on master. I did have to remove the line paraview.simple._DisableFirstRenderCameraReset() to eliminate one error. Can you elaborate on the error you see? Thanks, Cory |
(0032888) Cory Quammen (developer) 2014-06-17 16:09 |
Alan, I still cannot reproduce this on either Linux or Windows. Can you retest and close this bug if it works for you? Note that you need to remove the line paraview.simple._DisableFirstRenderCameraReset() Thanks, Cory |
(0032889) Alan Scott (manager) 2014-06-17 16:49 |
Cory, I had Utkarsh try this, and we figured out the confusion. I cut this script (at bottom of this note) in Windows, then pasted it into the Linux Python console using the middle mouse button. This failed, and Utkarsh replicated it. Then, we tried pasting with <ctrl>-V, and that worked. Thus, the issue has to do with pasting in Linux, with the middle mouse button. It is not critical this bug gets fixed for the 4.2 release (although I wouldn't complain if it did get in). Here is the script Utkarsh and I used: try: paraview.simple except: from paraview.simple import * Sphere1 = Sphere() RenderView1 = GetRenderView() DataRepresentation1 = Show() DataRepresentation1.ScaleFactor = 0.1 DataRepresentation1.SelectionPointFieldDataArrayName = 'Normals' DataRepresentation1.EdgeColor = [0.0, 0.0, 0.5000076295109483] RenderView1.CameraPosition = [0.0, 0.0, 3.2903743041222895] RenderView1.CameraClippingRange = [2.2624705610810665, 4.592229918684124] RenderView1.CameraParallelScale = 0.8516115354228021 Render() |
(0035171) Cory Quammen (developer) 2015-09-03 17:35 |
Debugging notes for myself: In pqConsoleWidget, the command buffer is set to be the text following the InteractivePosition member variable. When middle-clicking, InteractivePosition gets set to 653, presumably the end of the pasted buffer. When using ctrl-V, InteractivePosition is 146 (after all the preamble stuff). TODO - figure out why the InteractivePosition is being moved to the end of the pasted buffer when middle clicking. |
(0035174) Cory Quammen (developer) 2015-09-04 12:51 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/355 [^] |
(0035425) Alan Scott (manager) 2015-11-04 21:31 |
Yep, that works. Nice. Tested Linux, master, local server, OGL2. |
2013-11-01 16:20 | Alan Scott | New Issue | |
2013-11-04 11:18 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
2013-11-04 11:19 | Utkarsh Ayachit | Note Added: 0031824 | |
2013-12-07 00:09 | Cory Quammen | Note Added: 0031910 | |
2013-12-07 00:09 | Cory Quammen | Status | backlog => active development |
2013-12-07 00:11 | Cory Quammen | Note Edited: 0031910 | |
2014-06-17 16:09 | Cory Quammen | Note Added: 0032888 | |
2014-06-17 16:49 | Alan Scott | Note Added: 0032889 | |
2014-12-22 23:20 | Cory Quammen | Status | active development => todo |
2015-09-03 17:35 | Cory Quammen | Note Added: 0035171 | |
2015-09-04 12:51 | Cory Quammen | Note Added: 0035174 | |
2015-09-04 12:51 | Cory Quammen | Status | todo => active development |
2015-09-09 09:57 | Utkarsh Ayachit | Status | active development => customer review |
2015-09-09 09:57 | Utkarsh Ayachit | Resolution | open => fixed |
2015-09-10 16:27 | Cory Quammen | Relationship added | related to 0015612 |
2015-11-04 21:31 | Alan Scott | Note Added: 0035425 | |
2015-11-04 21:31 | Alan Scott | Status | customer review => closed |
